Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Cheap/simple relay/resistors attenuator for RPI
Old 9th December 2018, 05:44 AM   #31
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
That's what I did to add a volume control to my 'external' DAC. I have since move on to a different setup (not so.mucg related to the relay attenuator). Let me know if you want my relay board.
Group buy for augerpro waveguides for Scan Speak tweeters -- elliptical version -- circular version
Old 9th December 2018, 09:12 PM   #32
TrueReligionVinyl is offline TrueReligionVinyl
Thank you mbrennwa; I have PM'ed you.
Looking at the Volumio documentation, the graphical volume control goes from 0 to 100, but the Allo attenuator goes from 0 to 64. Has anyone tweaked the Volumio source to get a one-to-one mapping from UI to attenuator dB? I will use this for recording, so if my current level peaks at -15.6 dB, then I want to add exactly 15 dB so that my recording peaks at -0.6 dB. That means I need a one-to-one mapping from UI to attenuator level.
Old 10th December 2018, 07:02 AM   #33
mbrennwa's Avatar
Yep, Volumio (or the corresponding plugin) does that.
Old 1st September 2019, 07:50 PM   #34
psynapse is offline psynapse  France
Default using the attenuator with Buster
My apologies for re-opening an old thread. I have one of these attenuators and am very happy with its performance. However I am not using Volumio and so the only way I have of controlling volume is through direct access over the i2c bus. I would like to tie the attenuator to the volume in MPD, but it seems to me that MPD will seek to change the volume on the DAC. Does anybody have experience of using this device through ALSA / MPD??
Old 7th September 2019, 02:26 PM   #35
What software are you using to control the attenuator? I have been completely unable to get Volumio to control it - the GUI acts as though it is controlling it, but the volume never changes. Submitting logs and posting a message to the Volumio forum doesn't seem to do very much - two months with no reply. This is with Volumio 2.587 and version 1.3 of the relay attenuator plugin.
Old 15th September 2019, 11:38 AM   #36
mbrennwa's Avatar
I believe had to install a plugin in Volumio to make the relay attenuator work. Installing plugins can be trouble in Volumio if you changed the password of the default Volumio user.
Cheap/simple relay/resistors attenuator for RPIHide this!Advertise here!
ADC0804 Relay Attenuator Neutrality Analog Line Level 34 3rd March 2018 12:05 PM
Yet another relay attenuator jwb Solid State 34 21st July 2010 07:17 AM
YET another relay attenuator question robmil Solid State 0 14th April 2008 05:44 AM
relay based attenuator squadra Solid State 21 1st December 2004 10:10 PM
Ladder relay attenuator or so? Eccu Solid State 0 6th October 2003 11:00 AM
Copyright ©1999-2019 diyAudio
