Primaluna redesign knobs
About Primaluna amps, -why mount such un-readable knobs (vol+source) on a superbly designed amp, both inside and out. Large knobs with a tiny index mark, is design at the cost of function.
Replaced with vintage Luxman-styled knobs from don-audio.
Knobs for PrimaLuna
The dia. of the knobs are 32mm. You should know that the shaft of the volume pot is too long, and has to be cut down 5mm. No big issue, the shaft is made of quite soft aluminium. The art.nr. at don-audio is SUBLIME-S-32 (S for silver?). But check with Aaron Hannappel first, i notified him of my find of similar knobs with wider grip, probably with a deeper center hole. Maybee he got hold of them. And IMHO,- these knobs are even nicer in design -for the PL.
