Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
ID help - is this is a 110v or 220v transformer
ID help - is this is a 110v or 220v transformer Please consider donating to help us continue to serve you.
Old 3rd September 2016, 09:13 AM   #1
frangus is offline frangus  Australia
Default ID help - is this is a 110v or 220v transformer
I ordered a 220v tube amp but the transformer says 110v. See pic attached.
Im hoping its dual 110v
110v x 2 = 220v?
Old 3rd September 2016, 09:17 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
It is a dual 110V or 220V transformer dependant on how you wire the primaries. Series = 220V and parallel = 110V.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 3rd September 2016, 09:24 AM   #3
Many thanks Jon.
So is it safe to plug in? Or is there still a chance it could be wired for 110v?
Old 3rd September 2016, 09:29 AM   #4
Does this photo help?
Old 3rd September 2016, 09:45 AM   #5
Looking at the first photo it looks as if the red wires are connected together as the black wires are. Make sure the primaries are wired in series, ie; red live, black of that winding connect to the red of the other 110V winding , insulate the connection and connect the black from that winding to neutral.
Old 3rd September 2016, 10:02 AM   #6
It looks like one set of windings go the power input plug. The second set go to a switch. I dont really understand how this works? Would there be any other photos that would help or can i check with a multimeter?
Old 3rd September 2016, 10:04 AM   #7
subbu68 is offline subbu68  India
From second photo, where are those blue wires leading to? They look like wired up for 220V already.
Old 3rd September 2016, 10:14 AM   #8
The blue wires connect to one pair of the primaries. They are wired to the switch.
The other pairs of primaries are wires to the power input
Hopefully these extra photos help. I have pulled up the pair that goes to the switch for clarity
Old 3rd September 2016, 10:22 AM   #9
DF96 is offline DF96  England
You need a meter (to check that they got it right) and a lamp limiter (in case you get it wrong). We can't tell 100% from pictures.
Old 3rd September 2016, 11:37 AM   #10
It does not seem to be logical to wire one winding to the switch and the other to the socket. Are you sure it is a power switch?
ID help - is this is a 110v or 220v transformerHide this!Advertise here!
Using 220V transformer on 110V ZenCow Power Supplies 36 8th January 2011 01:58 PM
Using 220v transformer with 110v mains DarpMalone Power Supplies 7 10th March 2010 09:12 PM
110v power amp with 220v transformer, effects sound? Frosti Solid State 6 9th October 2009 09:49 PM
Solid State 110V to 220V transformer affects audio? Frosti Solid State 8 4th May 2009 08:39 AM
Aleph 3 with 110v->220v transformer roee Pass Labs 5 4th May 2004 09:59 PM
Copyright ©1999-2019 diyAudio
