Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
csr8645 ic
csr8645 ic
Old 19th July 2016, 07:06 AM   #1
michaelproino is offline michaelproino
Default csr8645 ic
I want to ask some technical questions related with Bluetooth audio,
I already worked with wt32i and I have completed my design, but I want to design my Bluetooth module,
for beginning : choosing csr8645 and getting it's dev board seems to be good,
Is there anyone in there working with this board?
Old 27th July 2016, 03:27 AM   #2
1audio is online now 1audio  United States
csr8645 ic
I have worked with the 8670. This is way out of normal hobbiest turf. If you can get a preprogrammed module so all you need to deal with is the I2S output life is much easier. make sure the sample rates coming out are supported in your hardware. They range from 8 KHz to 48KHz natively. Also confirm that the module has APT-X and if possible AAC turned on.
Good luck. I would get one of the packaged BT receivers myself. I'm much too lazy and even at its best is not that good.
Demian Martin
Product Design Services
csr8645 icHide this!Advertise here!
CSR8645 Bluetooth 4.0 AAC APT-X Module / Baseboard doctormord Digital Line Level 327 12th March 2020 07:37 PM
search pcb with IC tl494 or other Ic to build a smps caraudio Ground Zero Car Audio 0 13th December 2010 04:58 PM
What is the difference between an isolated IC and a non-isolated IC? DJ Exprice Chip Amps 16 20th June 2006 06:34 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
