Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Capacitor type for tube preamp
Old 19th March 2016, 11:46 PM   #11
Nikolas Ojala is offline Nikolas Ojala  Finland
Nikolas Ojala's Avatar
Arrow No love for mica.
Originally Posted by ericj View Post
No love for mica?
Do you like hysteresis?
Ref: The Sound of Capacitors
High-order harmonics are more offensive than low.
Old 21st March 2016, 11:26 AM   #12
cl1238 is offline cl1238  Australia
Thanks everyone for the info.
Old 22nd March 2016, 08:04 PM   #13
Bob Richards is offline Bob Richards  United States
Bob Richards's Avatar
Electrolytics should be replaced if they're old and weren't used much (the applied voltage apparently maintains the integrity of the dielectric over time, and lack of it allows deterioration). With regular use, I've got many electrolytics that still work great after 30 years. Some ceramic caps are significantly non-linear and temperature sensitive. I only use those in the power supply circuits (a .01u 3kV across the AC line and across the primary and secondary power transformer winding). Most plastic dielectric caps are fine. I try to use polyprops or polystyrenes when I can, and go with other plastic dielectrics (mylar etc.) when I can't get what I need in PP or PS. The bigger issue might be the manufacturers. Most are fine, but there may be some "boutique" brands that don't really know what they are doing. In a tube circuit, make sure the voltage rating is more than enough at turn-on, when B+ is significantly higher than when the tubes start conducting, and load down the power supply.
Old 22nd March 2016, 08:08 PM   #14
ericj is offline ericj  United States
ericj's Avatar
Electrolytic capacitor chemistry has come a long way in even the last 20 years. It generally makes sense to replace them.
.:Sent by pneumatic tubes
Old 22nd March 2016, 08:32 PM   #15
juanitox is offline juanitox  France
juanitox's Avatar
No love for mica?
i prefer silver mica than Polystyrene in coupling application more natural Highs for me .. cheap to try
French is not a crime.
Old 30th August 2016, 02:27 PM   #16
dotneck335 is offline dotneck335  United States
DIY Audio guru Rod Elliott says:
"Once someone starts sprouting utter BS about the "audibility of capacitors" they are no longer credible.*There is no credible evidence that any film cap is aurally different from any other."
Old 1st September 2016, 07:03 AM   #17
Gnobuddy is online now Gnobuddy  Canada
Originally Posted by dotneck335 View Post
..."There is no credible evidence that any film cap is aurally different from any other."
-Gnobuddy
Old 1st September 2016, 10:50 AM   #18
On Hiatus
SY's Avatar
This is true IF the corner frequency is well below the lowest frequency of interest, and that none of the caps are pathological (e.g., "hand made" with PTFE dielectric).
For filtering, it's plausible that some caps might sound different.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Capacitor type for tube preampHide this!Advertise here!
Type of Capacitor Harmon Parts 11 13th March 2015 11:37 PM
Type 37 tube preamp Too much stuff Tubes / Valves 1 28th December 2013 05:03 PM
Capacitor type mabnz Parts 4 1st August 2013 12:42 AM
What type of capacitor is appropriate? TheLaw117 Chip Amps 7 26th September 2010 12:44 PM
Capacitor Type ... Help papanohn Parts 8 13th November 2006 09:34 PM
Copyright ©1999-2019 diyAudio
