Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Beacon Transformer Data (New Zealand)
Thread Tools
Old 4th May 2019, 12:58 AM   #21
trobbins is offline trobbins  Australia
trobbins's Avatar
Coolgirl, PM me if Dagwood doesn't respond.
The catalogue shows a great range of hi-end output transformers, and indicates the importance of the core lamination material. It seems like Beacon used the same winding assembly and core stack outer dimensions for eg. variants like S06, S16 and S26, as the primary P-P winding resistance and leakage inductance are shown as the same.
Keen to hear from anyone with a Williamson amp with a Beacon transformers/choke :-)
Old 25th March 2020, 04:53 AM   #22
koolkarlnz is offline koolkarlnz
If any of you guys are around after 11 years I'm looking for information on the beacon 88C, I can't find anything at all. I just got a bulk lot of transformers to make some tube amps with and I'd love to get specs especially on the 88C (it's a big lad)
Old 26th March 2020, 12:47 PM   #23
trobbins's Avatar
The 88C would appear to use a model number scheme that was introduced after 1958 (https://dalmura.com.au/static/Beacon...0Catalogue.pdf).
Old 27th March 2020, 10:15 AM   #24
Thanks for that! Do you know where I might find data for it?
Old 27th March 2020, 01:36 PM   #25
trobbins's Avatar
All I can suggest is to try any and all NZ on-line technical and audio forums, and the radio association (New Zealand Vintage Radio Society – Keeping New Zealand Radio History Alive).
And don't forget to post back here if you come across anything in years to come :-)
Old 15th June 2020, 09:34 PM   #26
TonyGrimwood is offline TonyGrimwood  New Zealand
Does anybody have a pinout for the Beacon A26 octal-base 600-600 ohm tranny?
Tony
Old 16th June 2020, 04:58 AM   #27
PRR is offline PRR  United States
PRR's Avatar
A 600:600 will have two windings of about 60 Ohms DC. You can probably beep it out with ohmmeter faster than anybody could look it up.
Old 27th July 2020, 07:45 AM   #28
Dagwood is offline Dagwood  New Zealand
Dagwood's Avatar
Hi all,
Sorry I missed your requests, Ive not been on here for a while.
Here is a link to the copy I send Tim some time back
If you keep digging in the garden of failure you will eventually find success
Old 24th November 2020, 11:28 PM   #29
oldTnut is offline oldTnut
Hi everyone, I have a brand new beacon R134 transformer I purchased in the late 70's. (Actually got 2 of them). Looking to find out what all the tech specifications are, if someone knows. Cheers
Old 25th November 2020, 04:49 AM   #30
trobbins's Avatar
oldTnut, if you look through the 1958 catalog (linked to in post before yours) it indicates the R series is for power transformers, and yours is as you indicate - older than 1958.
No later catalog available so far - you may have to test for winding voltages, and use core size and winding dc resistances to estimate current ratings.
  Reply to this post
Beacon Transformer Data (New Zealand)Hide this!Advertise here!
Thread Tools
Regarding EDCOR Transformer Data kimbal Tubes / Valves 85 18th September 2014 11:20 AM
Testing a transformer without a data sheet bramofon Everything Else 7 20th April 2013 06:00 PM
Transformer Data oldschooltube Tubes / Valves 2 18th July 2011 02:20 AM
ortofon transformer step up data lt cdr data Analogue Source 3 21st February 2010 09:51 PM
HK330A Stereo Beacon Issues DreadPirate Solid State 6 9th December 2007 06:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
