Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Building an enclosure for an unknown speaker?
Old 4th November 2014, 04:46 PM   #1
KHesse is offline KHesse  Denmark
Default Building an enclosure for an unknown speaker?
Hello,
I recently replaced my old home theater system, and so I was leftover with my old Samsung HT-P1200 system. I decided to reuse the 2 rear surround speakers and hooked them up to a MaxAmp 20 powered by a 12V switching PSU, and then connected the amp to my PC sound card, to give me 4.1 surround in my room. For the two remaining speakers though, I wanted to do something a little bit different.
Each of the speakers are rated at 130W rms, but I can tell you that they're plenty loud running through my MaxAmp20. Inside of each speaker are two 2-13/16 inch midrange components, and a 13/16" tweeter. So that leaves me with 4 of the midrange components. I decided that I might use them in creating a small portable system I could lug around. The purpose of this is not really to get the most bang-for-the-buck, but also to just have a fun hobby project, and for the novelty factor.
Problem is of course, I don't know the optimal enclosure for them! I have a rough sketch of the design I'd like. Currently though, I feel like it might be a bit too big, as it's based off a design I found elsewhere on the internet, using 4" drivers.
I see two ways of mitigating that.
1: Shrink the cabinets, they're currently 3.4Liters. Maybe to 2.5?
2: Add another set of components on the backside. This would provide some feeling of surround sound, which could be very nice. Perhaps doing this, and then making each bass port about 50-60mm deep could work?
Here's some pictures to give you an idea of what I'm working with
Old 9th November 2014, 11:41 PM   #2
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Just build sealed boxes for such tiny drivers.
Old 10th November 2014, 12:10 AM   #3
R.I.P.
Sometimes its best to stick to mm to avoid confusion.
Your not being clear at all about anything, your explanation
is utterly confused and it is impossible to understand.
rgds, sreten.
Old 10th November 2014, 12:40 AM   #4
DUG is offline DUG  Canada
Unless you have the speaker parameters (or will measure them and you could see what a different volume would do to them) you should stick to the original volume they were used with.
If not, it is hit or miss.
Good luck.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 10th November 2014, 02:31 PM   #5
sherpa is offline sherpa  United States
Zigmahornets, I built a set for some 4" drivers i got out of a yamaha center channel speaker and was impressed. The wife actually allowed them for the bedroom system.
Building an enclosure for an unknown speaker?Hide this!Advertise here!
unknown speaker help dnic77 Multi-Way 5 19th June 2014 12:00 AM
Enclosure for small sub with unknown specs skirmitt Subwoofers 0 14th June 2012 03:59 PM
unknown speaker Bull Car Audio 2 23rd April 2008 09:05 PM
Unknown Speaker Brand sound_prodigy Multi-Way 1 15th August 2006 12:15 AM
Designing enclosure with unknown Thiele-Small params? Datoyminaytah Multi-Way 0 2nd August 2004 08:42 PM
Copyright ©1999-2019 diyAudio
