Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Switch grounds? Also make B4 break or break B4 make?
Old 22nd October 2014, 09:20 AM   #1
semmyroundel is offline semmyroundel  United Kingdom
Default Switch grounds? Also make B4 break or break B4 make?
Hi all, I was wondering cos I've read here many opposing opinions on these two subjects, firstly, (I'm building a 300w D/T class amp, Amp15-XP from 41Hz) I use shielded RCA inputs anyway, should I bother with a 4p3t switch (i've now decided that I may have 3 inputs) and switch the grounds to avoid any possible ground loops, as opposed to using a 2p3t switch and commoning the grounds?
Also, when choosing a switch, should it be make before break or break before make, and what is the thinking behind THAT answer?
Thanks.
  Reply to this post
Switch grounds? Also make B4 break or break B4 make?Hide this!Advertise here!
New B4 active crossover Nelson Pass Pass Labs 17 2nd October 2015 12:09 PM
Is B4 still on the horizon? Michael Rothacher Pass Labs 12 14th March 2011 11:46 PM
The "Make Before Break" connection for audio interconnects (MBB configuration) neazoi Analog Line Level 13 28th June 2010 08:26 AM
Any news on B4? Chul Pass Labs 5 9th December 2009 03:50 PM
Stepped attenuators - break before make? Eusebius Tubes / Valves 6 14th September 2006 09:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
