Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Modern replacement to Regulator LM317 With low noise ?
Thread Tools
Old 15th March 2014, 09:06 AM   #1
dazzz is offline dazzz  Israel
Default Modern replacement to Regulator LM317 With low noise ?
Modern replacement
to Regulator LM317-T With low noise ?
Old 15th March 2014, 11:30 AM   #2
JonSnell Electronic is online now JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Nothing wrong with the LM317. The capacitor on the output pin, blocks all of the 'noise'.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 15th March 2014, 11:38 AM   #3
I already know all about matching to output capacitor -esr
And selecting capacitor Cadj in the lm317
I Want recommendation
Regulator in the same configuration of LM317
Regardless of price that better
Old 15th March 2014, 12:04 PM   #4
Knorfski is offline Knorfski  Netherlands
I would say the LT1085.
Old 15th March 2014, 12:05 PM   #5
R.I.P.
Hi, LT1086CT is allegedly better, rds, sreten.
Old 15th March 2014, 12:07 PM   #6
Thank dear brother
Old 15th March 2014, 01:29 PM   #7
I'm probably going to change the regulator lm317
to
LM1085
For my project on the ARCAM FMJ PRE
To create a voltage of 5 volts positive
I need resistors
121Ohm
And
365Ohm
Currently in the ARCAM PRE
the smd resistor ar
470 OHM resistor ( R1)
1220 ohm and 220 ohm (R2)
So my plan
Replace the (R1) to 121 ohm
and
(R2) to 121ohm+243 ohm
the output capacitor and the adjast pin cap i chenge to 22uf
KEMET - T356K226K035AT - CAP, TANT, 22UF, 35V, RAD
and the input smd 100nf capacitor
i change to 10 uf rubycon ZLH CAP
Old 7th January 2018, 01:35 PM   #8
dennisyuan is offline dennisyuan
me too.
my choice is LT1085
Old 7th January 2018, 02:38 PM   #9
bandol83 is offline bandol83  France
R.I.P.
I think LT3080 is better if you don't need 7.5 A
  Reply to this post
Modern replacement to Regulator LM317 With low noise ?Hide this!Advertise here!
Thread Tools
Best low noise regulator? analog_sa Power Supplies 574 2nd January 2020 11:59 AM
Modern ultra low noise LDO - ADM7150 canvas Power Supplies 113 3rd March 2015 10:47 PM
Low Noise +-10V regulator dimkasta Power Supplies 5 22nd March 2012 08:48 PM
The simplistic Salas low voltage shunt regulator vs. LD1085/LM317 dvb projekt Power Supplies 20 5th January 2010 03:29 PM
ForSale: LT1085CT Low noise Regulator tone Swap Meet 0 10th September 2003 07:22 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
