Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Switched mode power supplies
Thread Tools
Old 3rd January 2004, 12:11 PM   #11
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally posted by Magura
A. How about getting +30-0- -30V, is that possible in a reasonable way?
B. How about an option to regulate the output voltage, lets say from 12V to 30V ?
Magura
Ans. A -- yes -- with two transformers, or one very good center-tapped transformers, or one transformer with two secondary windings.
Ans. B - by regulating the duty cycle you can regulate the output (but other things come into play.) use an optocoupler to sample the output, compare to an adjustable voltage reference.
you can also throw a linear regulator on the output -- an LM317 with a pass transistor.
Old 3rd January 2004, 12:51 PM   #12
millwood is offline millwood  United States
Account Disabled
Originally posted by Sch3mat1c
All I've heard is that they are noisy as all hell but nobody's yet given me a reason why this noise can't be filtered,
Tim
I used one (12v 3a) to power my active heatsink. the smps sits next to my jlh without any shielding or additional filtering. Zero noise that I can tell - the smps runs north of 150khz if I recall correctly.
it has 5 parts including the smps regulator.
Old 3rd January 2004, 01:21 PM   #13
jackinnj's Avatar
The ancient Sorensen switchers which I bought off EBay have less % noise than a 7805 -- a few millivolts .
whether they are good for music remains to be decided --- I know that some ham radio ops are not pleased with the results on CW and SSB using switchers due to the big pulse demands and the comparatively slow response time (which can lead to RFI.) I guess bigger reservoirs are in order here.
Old 3rd January 2004, 05:44 PM   #14
Tony Salsich is offline Tony Salsich  United States
Tony Salsich's Avatar
Noise on the output of a switcher is always difficult to 'beat down' to a decent level for audio or instrumentation purposes. It usually takes a small lossy choke and some extra capacitors. After that, a linear regulator can do an amazing job of reducing noise. Most people (I was one) are skeptical of the efficacy of the linear as a filter with its limited bandwidth, but it does work with up to 100kHz noise (maybe higher).
It is also important to prevent radiated noise from coupling back onto the output.
  Reply to this post
Switched mode power suppliesHide this!Advertise here!
Thread Tools
switched-mode power suppies Dimitar13 Everything Else 0 19th February 2008 12:50 AM
PFC Switched-Mode Power Supply N-Channel Power Supplies 57 13th June 2005 07:56 PM
Switched mode power supply MMicke Car Audio 3 19th February 2005 10:42 AM
Switch mode power supplies ANTHONY2181 Swap Meet 0 15th August 2002 04:30 PM
Switched Mode vs Linear Power Supply royalmp2001 Solid State 4 12th July 2002 08:04 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
