Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
LT4320 active rectifier
Thread Tools
Old 22nd October 2013, 12:57 PM   #11
crt is offline crt  Indonesia
crt's Avatar
Originally Posted by Refugee1 View Post
The theory is that a diode will be heated by working currant multiplied by forward voltage in watts.
A FET driven by a square wave from the chip will be heated by the currant multiplied by itself and then by the on resistance.
The on resistance of FETs is getting lower every time a new part number is issued. These things now pay for themselves quickly in power savings.
Take a FET with an on resistance of 0.1 ohms and blast it with 10 amps. It will be heated by 1 what.
Take a power diode with a forward voltage of 0.6 volts and blast that with 10 amps and you get 6 whats of heat.
Do have a look at the data sheets in order to work out the power consumption of the parts you have already got.
Sorry you forgot to square those Amperage
so with 10Amp (0.1Ohm RdsOn) ==> 10 Watt dissipation
MOSFET with RdsOn lower than 20mOhm (high current) is easy to get, even in my country
Right now im using 3.1mOhm RdsOn MOSFET
Old 25th October 2013, 02:02 PM   #12
Refugee1 is offline Refugee1  United Kingdom
Refugee1's Avatar
Well spotted. I have seen electric power steering FETs with very low on resistances that would work very well up to about 60 or 70 volts in that circuit.
Old 25th October 2013, 08:15 PM   #13
ticktock is offline ticktock  Scotland
ticktock's Avatar
Some interesting data:
http://www.linear.com/docs/43273
http://www.linear.com/docs/43295
http://www.linear.com/docs/43332
Not cheap at all:
DC1823A - LINEAR TECHNOLOGY - DEMO BOARD, IDEAL DIODE CONTROLLER | Farnell Deutschland
Invalid Request
Where to get PCBs or even stuffed boards at a reasonable price?
thanks
Blaue Leuchtdioden machen blöd. (hb)
sent from NSA monitored device
Old 10th February 2015, 03:29 PM   #14
andrrewg is offline andrrewg  United Kingdom
Default Ideal PSU
Although the efficiency gain isn't massive especially at high voltages it does look like a nice way of doing a linear supply compared to a diode bridge. It will never match the efficiency of a SMPS (due to copper losses in the transformer) but its much simpler to build and potentially lower noise.
I'm thinking about designing a PSU using this chip. I would probably design it for +ve and -ve rails up to 72v DC output.
I could also design in transformer soft start using effectively solid state relays (giveing the added bonus of active switch on / off. Of course it could be build up with different components for lower voltage or without the soft start for smaller transformers.
By the way the chip is available in DIP8 package so would be easy to solder. The PCB could be designed with through hole, or just large surface mount components if prefered.
Does that sound interesting to anyone?
Old 24th February 2020, 07:13 PM   #15
Blitz is offline Blitz  Germany
Quick question...Do you think one could as well only use one half of this bridge, so basically a CT-transformer (Fullwave vs. Bridge) ?
  Reply to this post
LT4320 active rectifierHide this!Advertise here!
Thread Tools
5C8S rectifier psud2 modle/rectifier information ryuji Tubes / Valves 1 14th March 2011 04:54 PM
converting tube rectifier to solid state rectifier. tubo Tubes / Valves 26 24th December 2009 12:12 AM
Understanding an active full-wave rectifier 300b Solid State 2 29th September 2009 04:33 AM
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
