Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Lowest noise BJT transistor?
Old 17th October 2019, 08:00 AM   #141
mchambin is offline mchambin  France
As said:
Most audiophiles do not know about engineering.
Transistor junction temperature is not transistor case temperature.
Old 20th October 2019, 06:59 AM   #142
SyncTronX is offline SyncTronX  United States
SyncTronX's Avatar
Default LIGO Confusion
Originally Posted by johnego View Post
It's an interesting article and good research.
My problem is trying to read the graphs, even when magnified.
Colors should have been further divided
using .........
or - - - - -
& - . - . - . - . etc.
At least that would separate the higher cost resistors
from the lower cost resistors and we could better see
which gives best cost:quiet ratio.
Issues I continue to have with it follow.
Figure 6: Be my guest.
Figure 7: Yel is good.
lt grn: good.
dk blue/gray: good
royal blue good.
org & brown: mediumgood.
Figure 8: Red looks good, but which lt. blue?
royal blues looks good, but which of the 3 oranges?
Figure 9: Doesn't count, too easy.
Figure 10: Which resistor?
lt grn: Yageo RC1206 or Vishaly Dale CMF55?
dk grn: Mira 0805 or Roederstein SMM0204-MS1?
Yel: Looks Good.
Pink: Yageo MF0207 or Welwyn RC55Y look good.
Figure 11: Which Resistor?
lt Blu: Yageo RC0805 or Vishay MMS0204? Wrong one is noisy.
org: MIRA 0805 or Susumu RG-Series?
-- Sync
Old 20th October 2019, 08:00 AM   #143
johnego is online now johnego  Indonesia
I printed it, viewed in large size to see the color, made notes. After that it was easy because the bad resistors are grouped already. When resistance is 1k (and above), none of the 100ppm is good enough.
Old 20th October 2019, 01:36 PM   #144
gerhard is offline gerhard  Germany
gerhard's Avatar
They also use thick and thin lines, but that does not help much.
At least 2 of the better ones seem to be easily sourced:
< Durchkontaktierbare Widerstande | Widerstande | DigiKey >
< LTW964TPW06030DB00 Vishay Dale | Kits | DigiKey >
"That's right!" shouted Vroomfondel, "we demand rigidly defined areas of doubt and uncertainty!" "We don't demand solid facts! What we demand is a total absence of solid facts. I demand that I may or may not be Vroomfondel!"
Lowest noise BJT transistor?Hide this!Advertise here!
Can I build up these Darlington transistor if I use two BJT transistor ? gaborbela Parts 9 15th July 2010 07:30 PM
Which tubes are lowest noise? Joshua_G Tubes / Valves 49 30th January 2010 03:44 PM
Which is the lowest noise FET? Young Solid State 10 11th February 2006 05:20 AM
which is lowest noise bipolar? bane_982 Parts 1 4th March 2005 12:45 PM
Lowest noise levels difi Chip Amps 3 3rd March 2004 11:42 PM
Copyright ©1999-2019 diyAudio
