5 Pin DIN > Stereo RCA
Just a quick query, I'm trying to wire a stereo RCA connection from my PC into an old Amplifier that uses a 5 PIN DIN socket on the Aux-In.
I followed this diagram:
http://lh4.ggpht.com/-uSyEoWkAIck/SgrG9EIxgZI/AAAAAAAAHRI/jPSaNDzVyT8/PPI_DIN_Pinout.jpg
Basically combining the RCA grounds to the middle DIN pin and pairing the Left and Right RCA channels to the pins either side of the middle DIN pin, leaving the bottom two DIN pins unused.
Is this wiring correct as I can't test the cable until I have sealed up the DIN socket, so I wanted to be sure. Thanks.
