Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Best electrolytic capacitors
Thread Tools
Old 17th May 2021, 09:47 AM   #1881
Gonethesame is offline Gonethesame  France
Originally Posted by bucks bunny View Post
With a lack of knowledge of accurate pcb design this technique - known for decades now - must be evil.
With a lack of knowledge of evil pcb design this technique - known for decades now - must be accurate
Old 17th May 2021, 11:11 AM   #1882
johnego is offline johnego  Indonesia
Originally Posted by duncan2 View Post
Unless you are prepared to put in a lot of design time designing a PCB component & tracks layout old school point to point wiring will always be superior.
I doubt this to be true (anyone has done objective comparison? ). I think if you don't know how to make a good PCB layout, you wont be able to make a good point-to-point layout either. So as long as you make the PCB comparably compact (to avoid mistakes, i.e. to avoid making some trace long when it should be short, or to make it wide when it is better not) the result COULD be similar.
Well, of course you can't make 3D connection with PCB but I think it is not necessary. Only in sensitive circuit where trace inductance or capacitance can cause oscillation the technique to float the circuit (or to use guided ring PCB layout technique) is important. In normal power amplifier Nyquist stability is mostly determined by other things.
In the old time, the part leads are all made of tinned copper (so P2P is okay). Nowadays I think many parts have some steel components. This material should be made short imho.
For breadboarded circuit I usually use copper from crossover coils. Two sizes, the big one for ground and power supply (of high currents), smaller one for the rest.
Old 17th May 2021, 11:20 AM   #1883
sumotan is offline sumotan  Indonesia
The other factor involved is board material which I believe affects sound too.
Frp is not good at least in terms of vibration damping. Dielectric effects me don't know, even for P to P, Frp vs Phenolic boards from what I hear from tube gurus also affects sound. Guess vibration is also evil hence good tube amps should also have tube sockets decoupled.
Old 17th May 2021, 11:29 AM   #1884
peufeu is offline peufeu  France
peufeu's Avatar
Originally Posted by sumotan View Post
FR4 is not good at least in terms of vibration damping.
Rubber standoffs.
True.
If you guys are comparing P2P wiring to single sided PCB, then P2P should win, obviously.
P2P over ground plane should also win compared to double sided.
P2P will even beat 4 layers at power plane inductance because kapton tape is thinner than 0.2mm prepreg. But if you want +/-15V power planes, mehhh...
But good luck with that P2P DAC, except ES9023, the package is user-friendly...
Old 17th May 2021, 02:10 PM   #1885
duncan2 is offline duncan2  United Kingdom
Quite right Peufeu its obvious those criticizing me for stating this have not spent many decades designing and building audio equipment long before it was made easier by virtualization and modern software .
They obviously never spent year after year reading on EW of well know audio design engineers amending their circuits due to layout and spent a very long time before they produced an actual PCB for others of equal stature to copy .
Its all down to visual looks now , if it looks nice it must sound nice and be technically perfect .
Wiring can be re-routed --just look at the advice given on DIY Audio -- move/re-route this or that wire even PCB computer designed circuits when when put into practical operation have the guy coming on and saying---"this should be perfect but its not --why ? " .
If there is any "magical art " in component and copper trace placement its entirely down to----experience.
Old 18th May 2021, 09:36 AM   #1886
Randall Smith on Reproducing the Magic in 'The Pit' - YouTube
Old 18th May 2021, 10:27 AM   #1887
bucks bunny is offline bucks bunny  Germany
Old 18th May 2021, 01:42 PM   #1888
This should be posted on the "Sound Quality Vs. Measurements" thread...
Old 19th May 2021, 02:25 AM   #1889
TonyTecson is offline TonyTecson  Philippines
diyAudio Moderator Emeritus
TonyTecson's Avatar
Originally Posted by jwags818 View Post
You are listening to the power supply. So I consider the entire power supply in the signal path.
i agree......wholeheartedly...
Old 19th May 2021, 03:37 AM   #1890
chris719 is offline chris719  United States
You appear to have absolutely no knowledge on electronic design after 1975. There are close to zero challenging designs that could be constructed by P2P techniques. I mean real-world challenging, not audio magazine circa 1980 challenging.
Best electrolytic capacitorsHide this!Advertise here!
Thread Tools
reforming electrolytic capacitors AndrewT Parts 76 22nd March 2021 12:32 AM
Electrolytic vs polyprop capacitors Puggie Parts 7 27th November 2020 10:46 PM
Lots of NOS Electrolytic Capacitors! ungie Swap Meet 27 29th February 2012 02:38 AM
4 pole electrolytic capacitors AGGEMAM Pass Labs 7 22nd February 2010 01:58 PM
Electrolytic capacitors akis Parts 13 16th August 2009 05:13 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
