Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Best electrolytic capacitors
Thread Tools
Old 16th May 2021, 05:20 PM   #1861
sumotan is offline sumotan  Indonesia
We're on the same page Blitz. We all strive to make our system as transparent as we can & yet making sound as realistic to our ears as possible. Hence the whole system from source to speakers has to work in synergy. We can't escape from not having components affecting sound. The better way to look at this is to understand the sonic characteristic of each component, capitalize on it to tweak & balance out the sound that we're looking for.
As for me say capacitors, I never use 1 brand or 1 type rather I use different caps or brands for different locations. What caps I want to use I already know its signature but that does not mean it'll sound perfect wherever I place them, for this reason I would have to test with different caps to hear its effect. Needless to say it is a very long & tedious way but for me this is the only way to achieve what Im looking for. There's no such thing as 1 cap for all, what sounds good at 1 location may only be so so on another.
Cheers
Old 16th May 2021, 09:08 PM   #1862
Zung is offline Zung  Switzerland
Originally Posted by sumotan View Post
... try out the Shindengen D4SBN20 or D6SBN20 bridge diodes. Smooth & grainless ...
Good tips. Thx.
Old 16th May 2021, 10:02 PM   #1863
peufeu is offline peufeu  France
peufeu's Avatar
when I build Mr Pass Boz preamp one was point to point they other build on pcb for a friend parts all the same on both, guess what, the point to point just sounded smoother & better, can't explain
Was it the same layout and did you keep pictures of both?
Old 17th May 2021, 01:10 AM   #1864
johnego is offline johnego  Indonesia
Dear Sumotan, what is the best el. capacitors for the usual feedback position?
Old 17th May 2021, 02:30 AM   #1865
TonyTecson is offline TonyTecson  Philippines
diyAudio Moderator Emeritus
TonyTecson's Avatar
silvered mica, polysterene caps....for feedback duty..
Old 17th May 2021, 02:54 AM   #1866
Not that one. The one around 220uF
Old 17th May 2021, 02:57 AM   #1867
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The one towards ground at the tail of a feedback resistors network that differentiates DC to AC feedback ratio in solid state amps? Prefer non polar there.
Old 17th May 2021, 03:27 AM   #1868
Salas's Avatar
ELNA RBD are good non polar caps for instance.
Datasheet
Old 17th May 2021, 04:30 AM   #1869
jwags818 is offline jwags818  United States
Location: Wilsonville Oregon, Corvallis Oregon native (You can't lick our beavers!).
You are listening to the power supply. So I consider the entire power supply in the signal path.
Jwags818 - Wilsonville, Oregon
D50s - 300B/D3A SET - 2 Way Transmission Line Speakers
Old 17th May 2021, 07:13 AM   #1870
Datasheet
Okay, thank you Salas. That one is not expensive, hopefully I can find it (locally). And better than my current stock which is Elna RJH.
BTW, I have several NP/BP (most popular is the green Nichicon Muse-BP) but they are not better than RJH.
Best electrolytic capacitorsHide this!Advertise here!
Thread Tools
reforming electrolytic capacitors AndrewT Parts 76 22nd March 2021 12:32 AM
Electrolytic vs polyprop capacitors Puggie Parts 7 27th November 2020 10:46 PM
Lots of NOS Electrolytic Capacitors! ungie Swap Meet 27 29th February 2012 02:38 AM
4 pole electrolytic capacitors AGGEMAM Pass Labs 7 22nd February 2010 01:58 PM
Electrolytic capacitors akis Parts 13 16th August 2009 05:13 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
