Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Best electrolytic capacitors
Thread Tools
Old 9th April 2021, 12:58 AM   #1841
TonyTecson is offline TonyTecson  Philippines
diyAudio Moderator Emeritus
TonyTecson's Avatar
psu caps are also in the signal path, they form zeros or virtual ac grounds....unavoidable, perhaps ac coupling caps is more doable...
poles and zeroes in case you are not aware are all over our amp circuits...
poles are responsible for lowering gains as frequency went up, while zeros are responsible for gains going down as frequency went down.....
we live with poles and zeroes in our everyday amps whether we like it or not...
Old 9th April 2021, 12:34 PM   #1842
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Actually this is correct, because there are still sound differences on listening tests - even by compare different electrolytic versions in power supplies.
But according of the real values for "Power Supply Rejection" (PSR/SVR) reduced.
Old 10th April 2021, 02:04 AM   #1843
Mark Tillotson is offline Mark Tillotson
I wouldn't phrase it like this, firstly as this sort of thing really applies to first-order zeroes and poles. Also its perfectly possible to have a zero in a low-pass circuit and a pole in a high-pass circuit (RIAA filter springs to mind for a zero in a low-pass).
Perhaps a better description is that first order zeroes change the response slope in a concave way, poles in a convex way.
Once you move to second order poles there is Q to consider - a pole pair may be highly resonant making a narrow peak in the spectrum, a zero pair can be a deep notch.
Old 10th April 2021, 02:07 AM   #1844
TonyTecson's Avatar
bypass caps in the psu rails of the super leach amps are first order zeroes...an rc network across ef86 plate load resistors in a Mullard 5-20 are first order poles...
this is what i was trying to say,
Old 10th April 2021, 09:45 AM   #1845
duncan2 is offline duncan2  United Kingdom
Its a wonder D.Self hasn't chimed in as he had a lot to say precisely on the subject of poles.
Old 10th April 2021, 10:27 AM   #1846
TonyTecson's Avatar
Steve Bench too....http://diyaudioprojects.com/mirror/m...sc/fb_faq1.txt
  Reply to this post
Best electrolytic capacitorsHide this!Advertise here!
Thread Tools
reforming electrolytic capacitors AndrewT Parts 76 22nd March 2021 12:32 AM
Electrolytic vs polyprop capacitors Puggie Parts 7 27th November 2020 10:46 PM
Lots of NOS Electrolytic Capacitors! ungie Swap Meet 27 29th February 2012 02:38 AM
4 pole electrolytic capacitors AGGEMAM Pass Labs 7 22nd February 2010 01:58 PM
Electrolytic capacitors akis Parts 13 16th August 2009 05:13 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
