Best electrolytic capacitors
Joined 2014
Well, I don't know... I've heard a lot about the benefits of oaken (or even hickory - gasp!) enclosures for your coupling capacitors. Those very knowledgeable in such matters have described the resultant sound as "Full and very dense with ear-coating tannins but also attractive fresh fruit, pretty acidity and a long finish. Rather chewy and needs time." Pretty hard to argue against something so compelling as that! :rofl:
Sorry, I sometimes get my wine and capacitor reviews mixed up. The same meaningful semantic content confuses me...
Reactions: 1 users
if you want to get more information in detail, ask there:
Jens Both
Elko-Consulting
Sieker Landstraße 123 b, D-22927 Großhansdorf
Phone: 0049 (0)4102 63757, jens.both@t-online.de
found by the URL
Elko-Consulting
Mr. Both works a long time for Valvo/Philips (development manager, manufacturing electrolytic capacitors).
There are several reports from him regarded caps. search for "Bad Caps".
in post 2234 under
https://www.diyaudio.com/community/threads/best-electrolytic-capacitors.151392/page-112
I have mentioned, that Mr. Both worked as an advisor for this company from China:
https://www.jianghai.com/enfile/upload/2020/03/25/CD137S.pdf
https://english.jianghai.com/about/aboutHistory_28.html
https://jianghai-europe.com/wp-content/uploads/Jianghai-Europe-Elko-Grundlagen-AAL-2018-09-18.pdf
(go to last page of this pdf for more details concerning older technical papers written by Mr. Jens Both).
Under
https://jianghai-europe.com/capacitor-competence-center/fachartikel/
are several technical papers as PDF available for download written by Dr. Arne Albertsen - both in German and English language.
In the attachment any examples.
I guess, that this brand is also a good choice for new projects, modifications and repair service and similar quality standard as on the brand FTcap is to expect.
Any experiences ?
  • Reststromverhalten moderner Elektrolytkondensatoren.pdf
  • Lifetime-Estimation of Electrolytic Caps.pdf
  • Jianghai-Europe-E-Cap-Reliability-AAL-2018-09-18.pdf
  • Jianghai-Europe-E-Cap-Voltage-Proof-AAL-2018-09-18.pdf
  • Jianghai-Europe-Lebensdauer-zyk-Lastprofile-AAL-2018-09-18-NEU.pdf
  • Technical_Notes for Elcaps.pdf
Administrator
Joined 2004
Hi tiefbassuebertr,
Please don't repost earlier posts.
Anyway, the important aspects may be some of the papers such was posted from Wurth. I'll take a Wurth capacitor over a Philips any day, they made the cheapest stuff going for years.
Have you read and understood any information or papers you posted? If not, read them first to make sure they are useful first.
Reactions: 1 user
  • Failure_Modes of aluminium-electrolytics.pdf
Administrator
Joined 2004
I haven't seen those here, and Philps only had tag type connections from what was carried here.
The normal Philips board mounted capacitors were not very good.. They were used in cheap amplifiers, generally a good place to start replacing things. They were also used in test equipment (Philips scopes) and tended to fail as well.
I don't have time to investigate a ton of links, I need a directed reason to spend the time. I do look at the data sheets for all parts when selecting components, but no way will I remember parts I reject.
