Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Thread Tools |
#1681 |
There is no best sounding capacitor Jesper. Since your aware of each caps pros & cons you can combine them like soem in PS & some in decoupling to achieve a sound that you like.
Re KZ only go for 50v version cause 25v version of the same value sounds dreadful. Btw he best sounding KZ that I found are the 22 & 33uf 50v version. In general my findings are 50v versions mostly sounds better then lower voltage ones. Cheers |
#1682 |
agreed !
I would try a phrase à la Linkwitz for the joke : "It's not one capacitor you are hearing but the sum of the defaults of all the capacitors on the circuitry" |
#1683 |
I have found that this is the case with KZ when they are undersized for that specific position or if the main power supply is not large enough. Try bumping up the size of the KZ caps if you get this. Or even increase the size of the power supply post-regulator caps if it's in a low voltage audio circuit.
#1684 |
#1685 |
100 hours, wow, more than a Black-Gate or a thermic motor... lol ! We can imagine what xill do the Auricap with the same burning in, uh !
#1686 |
@sumotan: Hi .. & thanks for your feedback. Although I am aware that there likely isn't any "one good" capacitor looking at the Denafrips Pontus - and remembering earlier designs with many of just one capacitor type - I was thinking/hoping that maybe a good overall capacitor could be found - and that one of you might have found this ONE (as I haven't myself).
Interesting also that the 22uF & 33uF 50V KZ versions are the ones you consider the best ... I reckon this is for decoupling as they do not provide much capacity for stabilizing a PSU voltage? @ainami: Thank you also for your feedback ... Well, actually the capacitors I am using are the 1000uF/50V KZs combined with Nichicon KG and GU - altogether about 54000uF for the input stage per channel and 72000uF for the output stage per channel. My personal thought about why the sound is a little screamy is that the 1000uF/50V KZs are rather large so I guess that their HF impedance probably is higher than the capacitors I used previously. And since the input stage has an appr. 11 MHz - 3dB point and the output stage a 2.2 MHz - 3dB point I reckon this could influence the stability of the circuits. I will see if/when I can find time to measure this. I in general agree with the notion of combining capacitors, however, in the long term I find it to be pretty hard on the PCBs soldering on and off so many times. Also, from a systematic point of view, I find it to be suboptimal to do it in this way as the circuitry has to warm up again, the solder joints and/or the new capacitor has to be run-in - and this may make hands-on comparisons "tricky". So to me at least it would be nice to find either ONE capacitor (e.g. one for digital circuitry, one for analog circuitry) that was the "Best", or a method to allow combination of suitable capacitors in a simple way. With regards to a method of combining capacitors I have been thinking of maybe using something like the Digikey analog discovery II and its impedance measuring feature to combine the appropriate sizes of e.g. KZ, Cerafine & KG/GU to arrive at a combination that yields a straight impedance curve from "DC to infinity" ![]() Anyway, I will be off on my Christmas vacation now so if there are any comments to this I won't be reading them until ~ 28 December. Merry Christmas to you ... Cheers, Jesper
"... It is always possible to be friendly ..." HH the Dalai Lama. |
#1687 |
I personnaly use the KZ 22 uF but in 100V iirc in the last stages of an amp, very good.
But in a voltage PSU... uh.. will not do that -personal tastes- but in a CRC PSU after the resistor, first C being a slower Long Life type... Lelon for instance ! Or why not an ELna Tonorex or even Silmic I don't like... CRC permits some fun ! No all in one cap as Sumo is saying. A forgiving one is the Panasonic FR, but even though there are some place I never use it... |
#1688 |
Sorry...all write about the sound of the capacitors but I don't understand if electrolytics del thread are good only where the signal passes or also on the power supplies.
I usually use Panasonic FC that are found all over the place and have a range that includes a lot of values and voltages, but I am also testing the electrolytics by Wurth electronics. Last edited by Pitrus; 6th February 2021 at 09:33 PM. |
#1689 |
The only high end gear I seen filled with full red cerafines silmics. Black gates ..are old marantz.
cd 94ii and I heard a few other old cd players have them . At the very most the Japanese high end have nippon chemicon (mostly)made for kenwood onkyo and so forth . The most expensive cd player by luxman d10x is just std nippon chemicon with maybe a few well placed boutique parts (like most high end equipment.) Cost like 20000 dollars . I had my own share of these boutique parts thousands of dollars ,and I absolutely careful with boutique parts because i cannot reliably guess the outcome . It just might turn into a piece of junk after many months of use and realise oh oh ..rubbish . They can become dark . Bleached , dull. First impressions is unreliable . Boutique caps are just too colourful and can waste alot of time figuring out which I don't want to waste . And high end nichicons are the worst , bleached .dark . dull. Ringing. All types of funny issues after burn in . And I am very familiar all the parts sound ..but risk failure .open up the box . Solder and wait again ..? Too much time .nothing better to do . Just a hobby. Wasted years btw.got pawned by standard off the rack equipment all day long . I trust and respect Nelson Pass who sold and designed way more amplifier than most of us here .I use mainly some silmics , elnas ,black gates if I can afford and hardly other boutique parts . But mostly good standard parts . The biggest difference to.sound is topology. And decent parts selection. And I EVENTUALLY made some very decent projects that respected golden ears approved. On a winning streak here.grin Just my 2cents worth |
#1690 |
I personally do not trust Wuerth.... might be just be a prejudice, but the origin of that company lies in screws, nuts & bolts. They still provide annual calendars with nude postergirls to workshops. Despite the sexy red sleeve, doesn't convince me at all... I mean, look at their datasheets
servus |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Electrolytic vs polyprop capacitors | Puggie | Parts | 7 | 27th November 2020 11:46 PM |
reforming electrolytic capacitors | AndrewT | Parts | 71 | 26th November 2019 11:57 AM |
Lots of NOS Electrolytic Capacitors! | ungie | Swap Meet | 27 | 29th February 2012 03:38 AM |
4 pole electrolytic capacitors | AGGEMAM | Pass Labs | 7 | 22nd February 2010 02:58 PM |
Electrolytic capacitors | akis | Parts | 13 | 16th August 2009 06:13 PM |
New To Site? | Need Help? |
