Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Hacking a new output to mixer
Old 18th January 2009, 09:00 AM   #1
Tribat is offline Tribat  United States
Lightbulb Hacking a new output to mixer
I just bought the Numark CM200 19" DJ Rack mixer and noticed that there is only one PFL output.
The Headphone jack at the front panel. Now I want to add another PFL line level output to the
backpanel of the mixer. Also the "Cue/Mix/PGM" crossfader meant for the headphone PFL output
should not affect this new output. So only the PFL (Cue) signal will be coming out this new output.
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
So heres the steps I was thinking about:
1. I open the mixer
2. I switch it on and route few channels to the PFL
3. I try to find a spot (with headphones) from the PCB where the mixed PFL signals can be stolen
Am i gonna find a spot like this?
So if there is a spot like that I was thinking of hooking a buffered op-amp amplifier to it.
Then I would drill a few holes to the backpanel for some new RCA connectors and hook the output of the
op-amp circuit to them.
I probably also need to drill a hole for a DC jack so i can power the 4 new op-amps?
So what do you think?
Old 19th January 2009, 05:14 PM   #2
gain wire is offline gain wire  Canada
gain wire's Avatar
I would try to get a schematic, it would be easier. But if not then as you mentionned, it seems logical. But I think you should be able to steal from the mixer's power supply if it uses the same power scheme (bipolar, or unipolar, doubtful they would have done that). good luck!
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig
Old 20th January 2009, 03:46 AM   #3
I don't think they release schematics.
The mixer's PSU looks awfully tiny, I found a picture of it from the Numark replacement parts shop. I don't wanna overload it
Old 20th January 2009, 01:50 PM   #4
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
You may find the Cue audio at one end of the Cue/Program fader.
Add a simple Opamp and feed the output of the opamp to a connector on the rear panel.
Frank
Old 20th January 2009, 04:49 PM   #5
Yes this is what I'm hoping to find 8)
Is there a reason to use two op-amps? First one to buffer and the second one to amplify the signal to line level?
Does anyone by the way know anyone who has done something similar? I couldn't find anything
Old 21st January 2009, 08:00 AM   #6
There is really nothing to be gained by using two Opamps.
Frank
Hacking a new output to mixerHide this!Advertise here!
Hacking a DAC out of a CD player - has anyone done it? Spasticteapot Digital Source 6 6th May 2010 12:13 PM
Hacking Coaxials GhettoSQ Car Audio 3 10th February 2005 08:14 PM
Maplin AV Amp 50 - Good for hacking? arniel Solid State 3 27th April 2004 03:54 PM
Extigy hacking info tiroth Digital Source 4 19th November 2003 03:21 PM
Hacking up $60 MP3 player sangram Digital Source 18 14th February 2003 07:57 AM
Copyright ©1999-2019 diyAudio
