Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Best opamp for audio, operating at +5V only
Old 18th August 2008, 10:58 PM   #1
trodas is offline trodas  Czech Republic
trodas's Avatar
Send a message via ICQ to trodas Send a message via AIM to trodas Send a message via MSN to trodas
Question Best opamp for audio, operating at +5V only
I have a dilema and I would like to hear your recommendation for best audio dual SOIC opamp, running at +5V only. Not much is there to choose from, but I'm sort of torn between these there:
AD823 http://www.analog.com/en/amplifiers-...s/product.html
LM4562 http://www.national.com/pf/LM/LM4562.html
AD8397 http://www.analog.com/en/amplifiers-...s/product.html
AD823 got a bad name for being too harsh and flat sounding (and hard to get one), LM4562 is picky a like to pick up interferences, not to mention still being a bit too much harsh/sharp ... (but I have few at hand) and I did not know much about AD8397, except that it could be get as sample easily.
The opamp will be used as LineIn input opamp on my X-Fi. Replacing a MC33078 opamp.
So, guys, are any of these even better that the TI original MC33078? And witch one would you recommend to install?
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
...just keep folding, just keep folding... my config
Old 20th August 2008, 05:51 AM   #2
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
LM4562 should win hands down on THD numbers and just about every specification. For sonics, you may also want to give the old TL062 micropower op-amp a listen - it will run on +/- 2.5v, but it's very close to the lower Vcc limit.
Old 20th August 2008, 02:00 PM   #3
danb1974 is offline danb1974  Romania
How about opa2134?
Anyway there is no universal best, just the one you like more how it sounds
Old 21st August 2008, 12:44 AM   #4
trodas's Avatar
Could be... how about these?
AD826 - slew rate - 350V/us, noise 15nV/Hz, supply 5-36V (CMRR 80dB)
AD823 - slew rate - 22Vus, noise 16nV/Hz, supply 3-36V (CMRR 75dB)
LM4562 - slew rate - 20V/us, noise 2.7nV/Hz, supply 5-34V (CMRR 120dB)
AD8397 - slew rate - 53V/us, noise 4.7nV/Hz, supply 3-24V (CMRR ~90dB)
AD8656 - slew rate - 11V/us, noise 2.7nV/Hz, supply 2.7-5.5V (CMRR 100dB)
OPA2365 - slew rate - 25V/us, noise 4.5nV/Hz, supply 2.2 - 5.5V (CMRR 100dB)
AD8022 - slew rate - 50V/us, noise 2.5nV/Hz, supply 5 - 24V (CMRR ~95dB)
AD8616 - slow rate - 12V/us, noise 8nV/Hz, supply 2.7 - 6V (CMRR 100dB)
Old 21st August 2008, 06:34 AM   #5
For fun... get some schematics of audiophile grade cd players and have a look at what they use. You may be surprised
  Reply to this post
Best opamp for audio, operating at +5V onlyHide this!Advertise here!
Best OpAmp for Audio Alchemy DITB arupg Digital Source 80 14th December 2018 05:43 PM
best TI audio dual opamp Leolabs Chip Amps 8 14th April 2014 09:40 AM
Audio CFB Opamp jackinnj Solid State 8 28th November 2007 07:44 AM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
Anyone know this audio opamp? jan.didden Solid State 4 29th May 2004 11:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
