Home Forums Rules Articles diyAudio Store Blogs Gallery Wiki Register Donations FAQ Calendar Community
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Normal temp of a 2 watt resistor?
Thread Tools
Old 28th May 2008, 07:07 PM   #11
cliffforrest is offline cliffforrest  United Kingdom
Get two 510R (or close) 5W wirewounds.
Stand them up vertically, one in each pcb hole, and solder the tops together.
One 10W resistor for 20 cents, last for ever, temperature < 50C
That is a crappy design, as is.
Old 28th May 2008, 08:24 PM   #12
Burnedfingers is offline Burnedfingers  United States
Post #4 looks like a Sonance 260 amplifier. Is there a R number by the resistor?
Old 29th May 2008, 02:32 AM   #13
turbo_slug is offline turbo_slug  Canada
Very good guess...it's actually a sonamp 2120 though. are you able to provide me the value of R021?
Old 29th May 2008, 03:27 AM   #14
Mayank is offline Mayank  United States
Mayank's Avatar
turbo-slug:
Very recently I went through a similar experience.
Had a Carver TFM-15cb on the bench with dead VU meters. Found two 2W resistors on the power supply to the VU meter IC, getting *very* hot. They looked very much like your R021. The design called for the voltage to be brought down from 52V to 8.5V These were actually 2.2k (yes, the red bands had become brown with heat). Poor design. I replaced them with 5W ceramic wire wounds. The VU meters work and the resistors get warm, but not as *hot*.
Good Luck
Mayank
Old 29th May 2008, 06:57 AM   #15
Mooly's Avatar
Hi
Post's 11 and 12 answered question . If you want to stick with just replacing the resistor, leave the leads "long" under the PCB and bend and solder them along the track. This will significantly reduce the "spot" temperature at each leg.
By the way, back to TV's again, it's not uncommon to see small heatsinks fitted to resistor legs (crimped on).
Old 29th May 2008, 10:58 AM   #16
I looked thru my files and all I have on those amps are schematics of the turn on circuits in which I signed a non disclosure agreement. If I can obtain the value I will pass it on to you thru email.
Old 29th May 2008, 04:40 PM   #17
Thanks for the help.
Is R021 in your schematics of the turn on circuit? I belive it's used in the circuit that switches the relay on/off.
Old 30th May 2008, 11:08 PM   #18
wakibaki is offline wakibaki  United Kingdom
Banned
120 degrees C is undoubtedly very hot, but evidently since a 2W part is fitted, some considerable dissipation was expected.
If it ain't broke, don't fix it...
Seriously.
w
Old 30th May 2008, 11:25 PM   #19
Mr Teal is offline Mr Teal  Canada
Get a resistor like this one.
Dale RHB
You might be able to mount it horizontally and drape leads through the hole. If not, grind down the solder lug until it's round and fits through the hole, and mount it vertically. It'll dissipate better that way anyway.
  Reply to this post
Normal temp of a 2 watt resistor?Hide this!Advertise here!
What's a normal temp for LM3886 on 40+40 DC? danielwritesbac Chip Amps 4 22nd January 2008 06:51 AM
2.7R zobel Resistor...Watt Rating? Wynand Chip Amps 12 7th October 2007 05:39 PM
Temp job Nixie Everything Else 41 24th February 2007 11:28 PM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
