PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
From PC to amplifier and back into PC - feedback problems?
Old Yesterday, 01:43 AM   #31
Sangram is offline Sangram  India
Sangram's Avatar
Glad you got it sorted.
To your distortion problem. When you say it plays back perfect over PA and badly in your software, is it exhibiting the issue when played standalone, or in conjunction with all the other mics?
Are the levels okay? Sometimes transients will cause digital clipping. Depending on what you're using to record and the bit depth, the level at which you clip may be quite sudden.
Old Yesterday, 02:28 AM   #32
Rick PA Stadel is offline Rick PA Stadel  United States
To elaborate on MAACO's point(s) in post 29 . .
The problem I see more often with such *mismatched* interfaces is 'low impedance stereo out (popularly 'MP3'), going to a balanced TRS input'. Users get sound, so they figure it's working. Trouble is, the 'ring' signal is being subtracted from the 'tip' signal! Since bass is largely the same on both stereo channels, it is greatly attenuated. And there's usually enough gain to make up the loss, so they just turn it up and lament the 'crappy bass'. You should see their eyes bug wide open when I lower the gain and back one of the plugs out one detent, and the quality goes way up.
Cheers
Old Yesterday, 07:21 AM   #33
MHarran is offline MHarran
It was when the mics were all on, I never tried it with that mic on its own. As I said in the second part of my post, the distortion has been eliminated by using the line in on the Creative USB soundcard so the problem was obviously with the PCís onboard sound; the input on the PC is a combined audio/microphone socket so perhaps that might have been the problem.
What bamboozled me was that the audio feed from the PA obviously consists of all the original channels (mics) mixed into a single track so I couldnít figure out how one mic was consistently giving the problem. Anyway, although a relative newbie to audio, I have a lot of experience with PCs and one thing I have learned is that sometimes you canít figure out where a problem was coming from, you just have to be grateful to solve it
Thanks again for your help
Old Yesterday, 11:33 AM   #34
krivium is offline krivium  France
Glad for you too.
Nice you've got some help from someone experienced nearby.
Old Yesterday, 04:47 PM   #35
The help I got here solved the problem before I got talking to the local guy - he said: "It's working fine, if it ain't broke, don't fix it!"
  Reply to this post
From PC to amplifier and back into PC - feedback problems?Hide this!Advertise here!
Problems with hybrid circuit / partial feedback. ErikdeBest Tubes / Valves 6 20th March 2019 09:39 PM
Negative Feedback Amplifier with embedded Positive Feedback Booster Koonw Tubes / Valves 57 24th June 2015 08:05 PM
Closed back midrange drivers - problems? River757 Multi-Way 6 17th January 2012 02:46 AM
feedback problems audio_moksha Tubes / Valves 11 28th March 2008 02:32 AM
Negative feedback problems on ECL82 SE amp. colinB Tubes / Valves 29 8th December 2007 08:13 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
