Digital Recreation of a Big PA System
Dua Lipa
Interesting. I can't imagine using compression for this reason only because as soon as I use it I feel the sound being compressed basically. But again this is probably because I'm working on music that is already compressed and limited, so I feel this would apply a bit more to the mixing stage, right?
All of the compression references have been to the Dua Lipa clip.
IMHO there's multi layered Electronic Drums that have also been EQed boosting the 50-100 Hz region - if you want a more realistic kick drum sound, attenuate the 50-100 Hz band/boost < 50 Hz.
Here's an example with good 40 Hz EDM of multi layered drums (10 of, according to the Producer).
Carly Rae Jepsen - Call Me Maybe - YouTube
In comparison, the music I'm trying to remaster is all over the place in the low end, bouncing off and building up. And they also tend to sound muffled, like they don't totally breathe and there's this sense like it's a bit "behind the speaker", not truly reaching out and speaking to you intimately.
Ah, the nub of the problem!
It's probably midbass in the 150 Hz region - have you tried notching this region out with EQ?
That would be a start in identifying the frequency band it lies in, as you're clearly happy with the 50-100 Hz waveshape of the Dua Lipa clip.
ground stack
flying pa and yes there is a difference in scale
then there's also
here flying and ground stacks are combined, all are different in what they deliver.
Multiband Compressor
Thanks megamond. Any reason for this particular compressor?
Because when Mark demonstrates it with music and compares with the original at around 10m30s I feel the same pressure of the compression as with any other compressor...
It's multiband adjustable, but as I said, I find the Drum Kit preset perfect for toning up the drums on "thin" old vinyl tracks.
In the sample music clip, I heard a marked difference with Mark's compressor settings - less boominess (w/ dual x 6" BR sub cab: -3dB c. 31 Hz, 200W RMS continuous/8 ohms) AND you can hear a pronounced midrange "slap" of the drum head.
Hey megamond
Yes, I did find that in many cases this muffled aspect was around 200hz, but get into the trouble of removing too much of the musical content in order to fix it. This would be much easier to solve if I had access to the mix with separate tracks. I'm also trying to find which plugin corrects this bloatedness without smearing transients and removing too much or generating this pressure I feel with most eqs...
Still, it's one of the aspects, the other main one being issues below 60hz.
I'm experimenting now with dereverberation, to try and get more of the direct sound
It's a combination of a lot of things :p
Thanks for the help!
ground stack
then there's also
Hey turk 182
One of my references was exactly like the flying PA in a similar looking place, but the others, such as the one at the beach I mentioned was just a big speaker on a big stand, nothing as elaborate as the ones you show
something just occurred to me have you looked into "track thickening techniques" but in this case you would be using it on a master to replicate your "PA sound"?
even a basic recording package like Soundforge would allow you to do that.
Well, as I understand it thickening means adding more to the sound then it already has, to go from thin to thick, when what I'm trying to do really is remove what I feel there's too much of...
In a way I'm trying to de-thicken music to it's "bare components", which I can then make louder again giving a much cleaner, lively perception of the music.
Thanks again
Muddiness
Hey megamond
Still, it's one of the aspects, the other main one being issues below 60hz*.
Hence, room treatment in Studios - I've actually worked in a (Surround Sound) MCR with a lot of treatment like an anechoic chamber.
The midbass also allows your ear to locate sound, as opposed to sub 100 Hz - re the "behind" the speaker remark.
*I note that the drums on the Dua Lipa clip are definitely > 50 Hz (with reason, I'm sure) whereas the keyboard hits notes as low as 31 Hz fundamental frequency.
Hopefully, you'll get there with a plugin to your satisfaction.
turk 182 Click the image to open in full size.ground stack
Click the image to open in full size.flying pa and yes there is a difference in scale
then there's also
Click the image to open in full size.here flying and ground stacks are combined, all are different in what they deliver.
Good examples, here´s just one more :)
it can be used to remove content.
ok i get you, i get the same way looking at certain paintings...
