PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Digital Recreation of a Big PA System
Old 17th September 2020, 07:33 PM   #91
masterinsanity is offline masterinsanity
Originally Posted by turk 182 View Post
ground stack
flying pa and yes there is a difference in scale
then there's also
here flying and ground stacks are combined, all are different in what they deliver.
Hey turk 182
One of my references was exactly like the flying PA in a similar looking place, but the others, such as the one at the beach I mentioned was just a big speaker on a big stand, nothing as elaborate as the ones you show
Old 17th September 2020, 07:41 PM   #92
something just occurred to me have you looked into "track thickening techniques" but in this case you would be using it on a master to replicate your "PA sound"?
even a basic recording package like Soundforge would allow you to do that.
Well, as I understand it thickening means adding more to the sound then it already has, to go from thin to thick, when what I'm trying to do really is remove what I feel there's too much of...
In a way I'm trying to de-thicken music to it's "bare components", which I can then make louder again giving a much cleaner, lively perception of the music.
Old 17th September 2020, 07:43 PM   #93
Originally Posted by megamond View Post
It's multiband adjustable, but as I said, I find the Drum Kit preset perfect for toning up the drums on "thin" old vinyl tracks.
In the sample music clip, I heard a marked difference with Mark's compressor settings - less boominess (w/ dual x 6" BR sub cab: -3dB c. 31 Hz, 200W RMS continuous/8 ohms) AND you can hear a pronounced midrange "slap" of the drum head.
Thanks again
Old 17th September 2020, 10:14 PM   #94
megamond is offline megamond  Australia
Default Muddiness
Originally Posted by masterinsanity View Post
Hey megamond
Yes, I did find that in many cases this muffled aspect was around 200hz, but get into the trouble of removing too much of the musical content in order to fix it. This would be much easier to solve if I had access to the mix with separate tracks. I'm also trying to find which plugin corrects this bloatedness without smearing transients and removing too much or generating this pressure I feel with most eqs...
Still, it's one of the aspects, the other main one being issues below 60hz*.
I'm experimenting now with dereverberation, to try and get more of the direct sound
It's a combination of a lot of things
Thanks for the help!
Hence, room treatment in Studios - I've actually worked in a (Surround Sound) MCR with a lot of treatment like an anechoic chamber.
The midbass also allows your ear to locate sound, as opposed to sub 100 Hz - re the "behind" the speaker remark.
*I note that the drums on the Dua Lipa clip are definitely > 50 Hz (with reason, I'm sure) whereas the keyboard hits notes as low as 31 Hz fundamental frequency.
Hopefully, you'll get there with a plugin to your satisfaction.
Old 17th September 2020, 10:58 PM   #95
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
turk 182 Click the image to open in full size.ground stack
Click the image to open in full size.flying pa and yes there is a difference in scale
then there's also
Click the image to open in full size.here flying and ground stacks are combined, all are different in what they deliver.
Good examples, here´s just one more
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 18th September 2020, 01:44 AM   #96
turk 182 is offline turk 182  Canada
it would be awesome to own a suitably equipped DeLorean and go back and catch a Grateful Dead show with the Wall O' Sound just to compare that to what modern PA sounds like...
Old 18th September 2020, 01:53 AM   #97
it can be used to remove content.
ok i get you, i get the same way looking at certain paintings...
Old 19th September 2020, 12:48 PM   #98
Default Suggested Plugins
A YouTube suggestion, but some may achieve your aim, OP.
Top 5 Must-Have Plugins I use on ALL my mixes - YouTube
Old 20th September 2020, 07:10 PM   #99
Thank you all for your thoughts and taking the time to respond.
Old 23rd September 2020, 12:36 PM   #100
Yet another suggestion that YouTube sent yours truly, that sounds very relevant, OP.
Andrew Scheps: Giving Drums a Natural Room Sound - YouTube
Digital Recreation of a Big PA SystemHide this!Advertise here!
Turntable in digital system Gats80 Analogue Source 1 12th January 2018 06:54 AM
My first venture into a digital system. The Rug Doctor PC Based 1 13th April 2010 01:48 PM
Help with an active / digital system patherb Digital Source 24 2nd June 2008 04:52 PM
PS for 5.1 Dolby Digital System WolfiS Power Supplies 7 2nd February 2007 12:18 PM
Digital Pots in 5.1 System rehanabid Chip Amps 25 20th April 2004 08:07 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
