PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
3way PA speakers
3way PA speakers
Old 15th June 2020, 01:01 PM   #1
Mihai Cimpoeru is offline Mihai Cimpoeru  Romania
Default 3way PA speakers
I have started building two 3way speakers using B&C 15NDL76, 8PE21, DE250 and Eminence H290B.
The enclosures are made from 15mm birch plywood, have a volume of 85L and are tuned to 50 hz.
Old 15th June 2020, 01:11 PM   #2
scholl is offline scholl  United States
Nice, the 15NDL76 with it's tight suspension like more power to sound it's best. For PA that's no problem.
Old 15th June 2020, 01:24 PM   #3
I have a Tamp TSA 4-1300 that was measured at 1300w per channel at 8 ohm, so there is enough juice for it (to bad it does not sound that great)
Old 22nd June 2020, 06:45 AM   #4
Did some measurements of the drivers, the crossover points will be somwere in the 600hz and 1600hz area.
Nearfield measurements show tunning at 45hz although impedance measurement shows it at 50 hz.
I also did some tests outside but the Tamp does not sound nice at all fullrange.
YouTube
Old 22nd June 2020, 10:06 AM   #5
chris661 is offline chris661  United Kingdom
chris661's Avatar
Does the 8" have it's own back chamber?
It's unclear from the pictures.
Chris
Bits of information and other things I've worked on: https://www.grimshawaudio.com/lab
Old 22nd June 2020, 10:23 AM   #6
Yes the mid has it's own enclosure made from a 20 cm diameter water pipe. The net volume is at 4.8 liters, enough to get it down to the frequency that i need.
File Type: jpeg WhatsApp Image 2020-06-22 at 13.20.51.jpeg (87.4 KB, 40 views)
File Type: jpeg WhatsApp Image 2020-06-22 at 13.20.51 (1).jpeg (112.4 KB, 43 views)
Old 25th June 2020, 08:12 AM   #7
kipman725 is online now kipman725  United Kingdom
kipman725's Avatar
Send a message via MSN to kipman725
I'm presuming the 15G and 45G measurements are 15 degrees and 45 degrees respectively? if you took closer spaced angular measurments you can put them in Virtuax cad to generate polar plots.
Old 25th June 2020, 08:32 AM   #8
Yes those are degrees. I need to make a measurement table to measure more precisely. Those degrees are set by using two rulers. I wanted to see the directivity of the drivers so i can match them at the crossover points.
3way PA speakersHide this!Advertise here!
Advice on measuring speakers for TMWW 3way montana1 Multi-Way 18 19th January 2018 03:18 PM
vintage Braun 3way compact speakers eyoung Multi-Way 1 17th August 2014 11:01 PM
3way 2way speakers midrange Multi-Way 5 2nd May 2013 07:49 PM
SOUND LAB A176P 3WAY FLOORSTANDING SPEAKERS ? laughingbuddha Multi-Way 0 18th March 2013 12:48 AM
3way Plasma TV Speakers. Help please. jimbo1968 Multi-Way 10 16th May 2005 07:44 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
