versatile system recommendations
Im looking for a system for small to mid sized events. Its going to need to be used for a variety of purposes, from playing background music at parties of around 30 people, to pushing the sound at a film night for 100 people. It will also need to be portable.
I know nothing is going to be ideal for every use, but I just need something with a good sound thats going to have as much versatility as possible.
I am currently looking at the Fender Passport Event PA system. does anybody have advice or insight? I know my headphones and home audio, but I have zero experience with event systems and am not sure if im even looking in the right direction :S
Joined 2007
Although I have never heard the L1 system I have heard other systems made by Bose that share the features of many small drivers and 'compact sub' and found them lacking for music playback. The small drivers sounded shouty and the bass unit quickly overheated and became ineffective (internal limiting).
A lot of what to recommend depends on your definition of partability and the amount of money your willing to spend. The best systems, even if compact will cost many thousands of pounds.
For portability I find the Bose L1 system is excellent and cost effective.
Are you sure?
Last time I heard an L1 I shut it off about a minute into playing some music. There was no lower-midrange "body" to the sound, among other defects. There are also much cheaper systems (EV's springs to mind) that are similarly "meh".
They produce sound, but so do those boxes of 16x piezo tweeters.
To the OP, a pair of 8" 2-way speakers over a pair of 12" subs will probably do just fine for you.
The minimum PA speaker I'd ever recommend is a Yamaha DBR10, with the DXR range being a useful step up in clean output.
Shop around a little, and don't be afraid of buying 2nd-hand.
I'd also recommend you stick with active speakers, since they'll have built-in processing, protection, etc. Passive speakers are less useful these days unless (like me and some others) you're DIYing the speakers with a particular purpose in mind, and have the capability to set up a PA system properly.
Add a notepad mixer to put control somewhere sensible, maybe a mic (the oft-recommended SM58s are okay, but there are better options out there) and a spare line input for mobile devices, and off you go.
Chris
Really quick, mono, full range, one box, allows 3 or more line level sources to be mixed, a Peavey KB300. Not suitable for solo guitar, but good for cd players, computer sound, MP3 players, radios including satellite, and of course keyboards. don't see these on the used market much (not fragile), but see them on stage a lot in small venues like the newgrass festival.
In the ultralight category, I'm using a 75 W mixer amp (mono) (MMA-875t) and a 8" whizzer cone speaker in a 14" long box with a bass reflex hole in the back. Fits in my bicycle bags with the autoharp or keyboard, has phantom power to power my KSM27 mike which picks up both my voice & my instrument. Visaton makes some nice 6.5" & 8" 8 ohm 60W whizzer cone speakers, made in Germany. The box is 8"x8"x14" cardboard from amazon, spray painted. I don't play in the rain.
If it has to be stereo, Peavey makes a 3 channel system with 2 two-way speakers on stands with 8" mid-range, and a 12" or 15" woofer for center in front of the stage. I think these are self powered, which mean you'll need a line level source as listed under KB300. The advantage of speakers on stands, they project out over the heads of a standing chattering crowd so the people in the back can hear if they want to. Disadvantage over a kb300, longer setup time. The mono bass is acoustically correct, because of the long wavelengths bass is determined from the room reflections anyway, bass is not really heard as stereo.
How portable? And what kind of music are we talking? If there will be any modern genres played and you want fullrange sound with some real bass then a real sub isn't optional.
You should start by looking at what would be a good system for the largest event you will do.. which I know will be bigger and heavier than you would like, and then decide what compromises you can live with in a scaled down version.
That would only be suitable for the smallest of your events, it won't get loud enough to be heard over the 100ppl talking at the same time in a large reverbant room.
The system I supply for a 100p wedding consists of three EV speakers.. 1 EKX18sp sub and a pair of EKX12p tops. I bet that is a lot bigger and more expensive than you would like but I guarantee you it isn't overkill for a party of this size. You could step this down in size to something with 10" tops and a 15" sub or 8" tops with a 12" sub, but you will lose a fair bit of max output potential with each step. The upside of buying these professional powered speakers is any of the fullrange boxes can be used on their own for your smallest events and still produce respectable music playback sound and really good live vocals amplification.
An alternative to these traditional sub/sat PA systems would be the column systems that are very common now like the Turbosound iP series, EV Evolve, and yes even the Bose L1 variants... although that brand does not represent the best value IMO. These units are quite portable but don't drink the coolaid.. that does come at the cost of overall output capability compared to the same $$ spent on conventional PA speakers.
wow - i really appreciate all the responses - thanks guys! so to answer your questions:
the biggest events will be about 100 people, but those would be movie nights in a pretty quiet atmosphere. ive done these a few times in the past using my home system, which is a pair of kef ls50 speakers with a nuprime ida-8 amplifier.... those speakers only have a single 5" driver in them, and honestly? they get the job done fine. it would be nice to have a little more power, but the reason im looking for a different system isnt the sound or power, its the fact that theyre clearly not designed to be portablem and its just not feasible to keep dragging them out to events.
my budget is flexible up to $1500, but that doesnt mean im happy spending that much - if the fender passport event speakers will get the job done for $650 - then im not looking for reasons to spend more than that.
portability is a big issue for me - as is appearance. im experimenting with a lot of events right now, including things like restaurant pop-ups and art openings. to be completely honest, the appearance is probably more important in my field of work than the sound; im not working music gigs, im trying to do clean and professional setups at high end houses and galleries to provide atmosphere and background noise. if i could get invisible speakers i would.
they *do* need to be stereo - mostly for movie screenings. this is what turned me away from the bose L1 speakers - it does not look like they can run as a stereo system(?) i also agree with @chris661 that active speakers would definitely be preferable. minimal cables and quick setup are preferable too - but in my experience bluetooth has just been too glitchy to risk at events, so im assuming cables are just a necessary evil for events.
So i guess what im really looking for are two sleek and attractive, active speakers with 8-10" drivers, that can be hauled comfortably by one person, taking 5 minutes to setup and connect to a laptop, and possessing a minimal footprint... but from what im seeing, its hard to get speakers that fit that description that are designed to be durable and portable enough to be used for events, so ive just been looking at clunkier PA systems so far.....
Well, if it's portability first, grab a pair of Yamaha DXR8 Mk2s and call it good.
You get phono inputs and an XLR pass-through to send the other channel to the far speaker.
They sound fine and get reasonably loud - certainly much louder than your Kefs.
Chris
The equivalent Peavey product is the escort 6000 system with a PV118 powered subwoofer or a DM115 subwoofer which is smaller but weighs 5 lb more. The escort 6000 mixer has the subwoofer output split off. The escort is 300 watts/ch with stands and feedback locating system for microphone use. Escort 6000 is 58 lb packed, 17"w x 18"d x 40" high packed. The PV118 is 300 w & 85 lb.
The column systems are going to be the ideal solution given your needs for a minimum footprint as any conventional speaker will require a tripod stand. Have a look on Thomann UK for "column PA Systems" and spend most or all of your budget on a pair, if you got a couple of RCF Evox5 systems for example I think you would be quite happy.
The peavey escort 6000 comes with the stands, some cables, a case to pack the kit all up in.
I use a camera tripod for microphones in my microlight system. It packs up much smaller than a real PA stand and weighs 20 lb less.
The Peavey Escort 6000 comes with piezo tweeters and should be discounted if anything resembling high-quality sound is required.
Conanski, it's a good point about trip hazards - that's one of the reasons for my recommendation of a couple of 12" subs.
I've heard a few column systems, including Bose and EV, and couldn't recommend them in good conscience - no lower mids, one-note sub that stopped before 55Hz, and weird comby treble.
They seem to put form factor above all else. The RCF Evox range is reputedly very good, but I haven't tried them myself.
Chris
Joined 2007
As I earlier mentioned there are other styles of stand that will work if the speaker is not large:
Millenium BS 2015 Round Base – Thomann UK
Column speakers (weird dispersion, poor bass response, high distortion, cone breakup issues, ragged response) and peizos (high distortion, low power handling, ragged response) sound bad. If they sounded good we would all be using them, yet whenever high quality audio is required you see large heavy speakers.
Piezos beam pretty bad, narrow dispersion. I've got Peavey 1210 "high frequency projectors" with triple piezos pointed in 3 different directions, which covers the beaming problem. That's over dual 10" woofers. They sounded better on synthesizer than anything else I heard & could afford in 1984 at $300 the pair. The SP2-XT @ $650 the pair I have sound better, but at 90 lb I can't set one on the stand or remove it by myself. The 2" horn itself is about 8 lb. The 1210's are about 60 lb; if I ever own a car again I may use them in gigs again.
Hi Smaki,
The system i use is:
active speakers (Mackie Thump15's).
mixer is normally a PreSonus RM32ai but depending on the situation may be an analogue mixer (Behringer SX24fx).
Monitors (4 off Behringer B210D).
Case of mic leads (between 2m and 20m).
Case of microphones.
Case of mains leads.
Kit bag of mic stands.
Kit box (DI's, test gear &c).
Plus my instrument (Bass Sax).
All fits in the boot and back seats of my car (W124).
All the best,
Xx.
Yes, i've used the Bose column speakers and don't like them. Much like their old 802's, set up properly and run by someone who understands them, they can be good.
Just a quick note that I can't recommend (or see recommendations for) Mackie Thumps in good conscience. They made Guns 'N' Roses sound like the guitar was missing, and I wish I was kidding.
They'd be okay for light DJ use, but I'd still take 8" mains over 12" subs.
Chris
