PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
P.Audio BM12CXA -- need crossovers
Old 5th June 2020, 10:04 PM   #1
noviygera is offline noviygera  United States
Default P.Audio BM12CXA -- need crossovers
Hello,
Anyone have access to the proper passive crossovers or schematics for the BM12CXA + BM-D440 compression drivers?
This is a coax 12"
thanks!
Old 6th June 2020, 11:44 AM   #2
chris661 is offline chris661  United Kingdom
chris661's Avatar
I don't have them on-hand, but it's easy enough to design a passive crossover if you've got some measurement gear.
Chris
Bits of information and other things I've worked on: https://www.grimshawaudio.com/lab
Old 6th June 2020, 12:15 PM   #3
BesPav is offline BesPav  Russian Federation
Going passive you'll need first to move crossover point higher due to relatively low order and second put resistance for compensation of higher HF sensitivity.
First will result in bad directivity match. You'll have narrow needle at 1,5-2 kHz from 12" while 1" exit driver will be wide like 60 degree. This will provide you with a bad beaming across a whole 1-3kHz band where maximum of human hearing are.
Resistance at HF driver will highly reduce damping factor which is critical to high-quality factor HF driver.
So, there are a way better to use active filters.
Do you have some kind of measurement setup - mic and audiocard?
P.Audio BM12CXA -- need crossoversHide this!Advertise here!
Car audio crossovers for home use ozziozzi Car Audio 5 7th December 2015 06:48 PM
Thiel Audio CS 7.0 Drivers and Crossovers Thomas James Swap Meet 1 5th June 2013 03:50 AM
Joseph Audio 'Infinite' crossovers. Puggie Multi-Way 41 21st February 2011 09:07 AM
Crossovers question - car audio Tehbannage Analog Line Level 1 7th December 2010 05:42 AM
Car audio installation kits, accessories, crossovers, etc... feke67 Car Audio 0 26th May 2003 01:17 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
