PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Building a mixer for live vocal FX
Old 2nd March 2020, 09:46 PM   #11
Reknes is offline Reknes
Originally Posted by Enzo View Post
Since mixers are generally stereo, the idea of an output pan is confusing. That is why each input channel has a pan control.
Yes, I get that. I also want a mix knob for dry/wet (to get completely wet signals when improvising). A solution to the output pan would be to make a section on the mixer that sums the dry signal and the two stereo returns together and that I can make a mix knob at this stage, followed by a pan. After the pan it goes straight to an output (fader or pot for output volume, preferably a pot) and then to the physical outputs.
Old 3rd March 2020, 03:43 AM   #12
Enzo is offline Enzo  United States
Look at your AUX sends on the input channels. Some are "pre-fader" and some "post-fader". Some mixers have this switchable, some have jumpers inside you can change. Lesser mixers are set one way or the other, check the spec sheet.
Anyway, if you want effect only, and no dry, use a pre-fader aux send. That way you can send the audio to your effect, then simply drop that channel fader to zero. That way the effect will be coming in the return and the dry will be killed by the fader.
So for example I set up one channel to send pre-fade signal to an outboard FX unit. I can either turn the aux send to zero or the return to zero leaving only dry controlled by the channel. fader. I can then bring up the FX along with the dry, so IO have both. Then I can bring down the channel fader leaving ONLY the FX for some echo fade out thing. No need for a bunch of external controls.
By the way, some mixers have AUX sends that are pre-EQ or post-EQ. Depends on whether you want the channel tone controls to affect what you send out the AUX. This is a separate thing from pre and post fader.
Old 4th March 2020, 12:10 AM   #13
indianajo is offline indianajo  United States
indianajo's Avatar
I think I could do most of what you want with my Peavey PV8 and some cables and effects.
4 channels have an insert jack after the input gain. These are the channels that also have 48 v phantom power on the microphone jack. Inserts go out to an external effect on tip and back on ring. If your external effect is a footswitch with an analog switch that switches to silence, you've got item 5. My digitech quad 4 might be programmable to to silent, it has a footswitch. I think graphic equalizer effect with master slider to minimum would do the job. If you use a graphic equalizer as the effect, many have a bypass controlled by footpedal.
If you have both a vocal mike and an instruments mike, put vocal on channel 1 and instrument mike on channel 2. They can have different external effects.
You can bring in stereo line level inputs on channel 5&6 or 7&8, then there is a pan pot at the bottom for each.
Each channel 1-4 or pairs 5-8 have 3 band equalizers after the inert and before channel gain.
If I use the reverb in the digitech, I return it to 5 or 6, and turn the amount of reverb in the master mix up & down with the channel out pot or the 5&6 balance pot. Haven't needed to hook the digitech to the efx input (stereo) jacks yet. The efx return has its own in & out pots.
There are tape sends, monitor sends, stereo effects sends, control room sends (parallel headphone output) main sends. Monitor send and effect send mix can be different than main+controlroom+tape send mix.
If you absolutely have to send with a stereo plug, you can use the headphone output. But you'll get better hum rejection over long distances to the PA mixer using the TRS main mono sends, with a twisted pair cable for each.
I bought my first PV8 for $48 with freight from ebay, then replaced the master volume pot and fixed a broken PCB via that was killing all the left outputs. Very instructive exercise. I donated that PV8 to a church and bought a new one for $149 off ebay. the one at the church sits at the edge of the stage where it mixes the 2 wired vocal mikes into the organ amp+speakers. It sits on a Peavey 15 band stereo graphic equalizer. Each equalizer channel has a different slider turned down to kill the howl that comes from that mike. If only 1 of 15 sliders is down, a voice sounds more like itself than if the howl is killed with a 1 of 3 midrange pot on the stage mixer. The graphic equalizer was about $60, had one bad solder joint killing 1 channel. Trace it reheat it, just like new. Pots are fine on the graphic equalizer.
Beware, replacement PV10 has autotune for vocalists that never learned how to sing.
Happy shopping, and learning the ins & outs of performance PA gear.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 4th March 2020, 02:00 AM   #14
simon7000 is offline simon7000  United States
Seems to me adding a foot switch controlled mute to a send is just adding a small relay to an existing board at the right point on the circuitry. However as this will void the warranty, I would start with a used mixing board.
As you will already be playing with the insides you can even go for one with some bad inputs.
For your first try I would suggest you buy the cheapest one you can find. Playing with it will allow you do do a much better version 2!
Old 4th March 2020, 02:27 PM   #15
Thanks for the replies everyone. It’s really helpful. I’ll post updates and/or further questions in this thread.
Building a mixer for live vocal FXHide this!Advertise here!
Can a computer with an audio interface be used as a Live Audio PA mixer? Dolmetscher007 PA Systems 10 28th March 2019 08:33 PM
construction of 8 channel live digital audio mixer Hamza Khan PA Systems 19 19th October 2018 10:25 AM
Soundcraft Spirit Live 8 channel mixer AJDMGM Swap Meet 1 3rd October 2018 10:10 AM
Building a DJ mixer liddokun Instruments and Amps 42 15th July 2017 06:09 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
