PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
All passive zero power system
Old 4th March 2020, 11:16 PM   #11
Mark Tillotson is offline Mark Tillotson
Originally Posted by Michael Bean View Post
I was referring to what you said, "an all passive audio amplifier"...there is no such thing, for amplification to occur, you need an additional power source to amplify, there's no free lunch.
You are assuming _power_ amplification is the only sort we talk about - it isn't. A transformer can serve as an MC preamp section, giving voltage amplification completely passively. Mechanical amplification can be done passively with levers gears etc, so long as its position or velocity of force amplification rather than power amplification.
Amplification is about making some physical quantity bigger, and not all physical quantities are conserved like energy/power. In electronics we talk about voltage amplification, current amplification and power amplification - most commonly active, but sometimes passively. Power amplification of course requires active components, but the other sorts are sometimes passively boosted with transformers or switched capacitors, etc.
[ actually switched capacitor networks are interesting in that the power is not supplied/amplified by the switching device, but rather only routed by them, hard to say if this is best thought of as active or passive ]
All passive zero power systemHide this!Advertise here!
Which 12'' to mate with the ATC dome in a passive system? leifislive Multi-Way 22 27th January 2017 08:22 PM
New passive PA system, very confused gullis PA Systems 18 4th October 2016 02:34 PM
f3 of passive radiator-system MCPete Multi-Way 12 29th February 2008 10:47 PM
Equalize a passive bi-amp system Sony Solid State 1 1st September 2005 02:54 PM
using a 4 ohm passive xo...in an 8 ohm system.. ChesterFuzzin' Multi-Way 2 22nd May 2002 03:27 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
