PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Letting amps clip or running a limiter?
Old 20th February 2020, 10:25 AM   #11
kipman725 is online now kipman725  United Kingdom
kipman725's Avatar
Send a message via MSN to kipman725
Originally Posted by TNT View Post
Avoid clipping. Period.
yes but this is the real world where my amps don't have unlimited output power and input signals can be unpredictable.
Old 20th February 2020, 08:49 PM   #12
turk 182 is offline turk 182  Canada
kipman725 are you playing back pre-recorded material or are you doing live sound?
Old 20th February 2020, 10:31 PM   #13
conanski is offline conanski  Canada
Originally Posted by kipman725 View Post
would it be better to choose a zero attack time over the recommended attack release ratio?
I think it is going to depend on the processor in question, on my DCX for example the only variables to adjust are threshold and release time and in my experience the settings have to be way off before they become objectional.
Old 21st February 2020, 09:46 AM   #14
kipman725's Avatar
At this party I'm doing DJ playback and live sound. My processor is a Symetrix Symnet 8x8 DSP. This is a free form DSP has a choice of 'compressor' or limiter blocks. The compressor has attack, release, soft to hard knee and ratio with the minimum attack been very short but not zero, it does not cause any processing delay. The limiter has zero attack time but causes a small processing delay (not enough to be a problem as long as every output is delayed by the same amount). The limiter only has choice of threshold and release time.
In terms of frequency bands I have:
500 - 20 kHz (Apart audio PA2120 120W, ~100dB/1W, top mid/high)
120 - 500 Hz (Apart audio PA2120.120W, ~100dB/1W, top midbass)
30 - 120Hz (nu6000 + P7000s, 4 subs that should do ~128dB/1m/2pi over that range)
I was trying to get a crown CTS4200 up and running for the tops which would give me in excess of 200W per channel but I'm uncertain it will be possible in time. The desk is probably an X32.
Old 21st February 2020, 02:43 PM   #15
chris661 is online now chris661  United Kingdom
chris661's Avatar
In my experience, it's fine to let amplifiers clip if:
- They don't sound bad while doing it
- The average power level is still kept under check
If your amp goes "crunch" when clipping, then obviously it sounds bad and that should be avoided.
Remember - loudspeakers don't care what the signal they're being fed looks like. If you push an amplifier 3dB into clipping, it's not the additional harmonics that kill the driver. It's the increase in the average power being delivered by pushing the fader by another 3dB.
A good engineer that's paying attention will be able to spot if/when the PA system is struggling, and act accordingly.
Chris
My work: www.grimshawaudio.com
Old 21st February 2020, 02:48 PM   #16
Damo s is offline Damo s  United Kingdom
The limiter ... causes a small processing delay
That's so it can anticipate the attack and soften the application of limiting to prevent what would otherwise be a clipped signal.
Ive got my PA management unit setup with a 40:1 compressor on the inputs which ultimately stops anyone (DJ) from overloading the PA. It's set to compress just a tiny bit before the sources master output level shows it touching the reds. So there is plenty of gain and a bit of red light flashing to keep DJs happy. (Certainly on the pioneer mixers with a bit of red flashing there is still some headroom under the hood, because they know DJs love smashing the reds). When going further into the red the compressor then starts crushing the life out of the music leaving it with no dynamics and unpleasant to listen to, although that doesnt always stop DJs from doing it. At least that cant overdrive the system.
Old 23rd February 2020, 03:44 PM   #17
mark100 is online now mark100  United States
Ime, limiting has to be split into two functions, with separate limiters for each.
RMS, or thermal limiting, like given in the powersoft chart earlier.
And peak, or excursion limiting, with near instantaneous action....
I know you know all this, just repeating for any who don't..
Since the Symetrix only appears to allow one of those limiter types at a time, I'd use it for Peak, and the compressors in the X-32 for RMS.
I didn't see what drivers your using...do you have the voltages in mind, RMS and peak, for each section?
Old 24th February 2020, 09:32 AM   #18
kipman725's Avatar
The DSP is free form so I can have unlimited (within the processing power available) of each type of limiter as any point in the signal path. Tops are three way with a passive mid high crossover:
15CM V2
4*3FE22
P-audio BM-D446
There is over 10dB of padding in the mid high crossover performing equalization functions and bringing the sensitivity of the mid/high down to 100dB/1w
Old 24th February 2020, 02:55 PM   #19
15CM V2
4*3FE22
P-audio BM-D446
Good, i mistook with Symetrix "a choice of compression or limiter block" to mean you had to choose one.
Which doesn't make any sense, because who would design a free form processor without both.
Anyway, a quick look at your drivers...and I would go in order:
40Vrms, 105Vpk
20Vrms, 50Vpk
15Vrms, 35-40Vpk
where pk is true pk (1.4 x rms)
Oh, and 20Vrms, 50Vpk assumes the 4 drivers are 2 sets of parallel in series.
I've found setting predictive limiting to be a bit of a pain, needing to measure actual amp outputs. But well worth it for peace of mind with live.
RMS and peak limiting are one piece of dsp i like in the amp, better than in the processor.
Old 25th February 2020, 09:08 AM   #20
kipman725's Avatar
Thanks for those numbers. I have already measured the gain and maximum output voltage of the amplifiers (2* Apart Audio PA2120) used for the above drivers . It can do 120Vpp so 42.4Vrms, 60Vpk (clip point). It also has a slow acting limiter built in that reduces the level to below the clip point if that happens repeatedly. The mids are wired series parallel:
BM-D446 on PH-4220
considering that the crossover is padding the mids down at least 5dB it would seem that the only driver that could be vulnerable to damage on these amps would be the tweeter if there was excessive >10kHz content.
Letting amps clip or running a limiter?Hide this!Advertise here!
Soft clip volume limiter idea Mark Tillotson Solid State 0 20th January 2020 01:02 AM
QSC clip limiter which part birgitay PA Systems 2 28th December 2018 05:40 AM
Clip limiter ionutzxpo Class D 9 16th December 2011 03:16 AM
how and why power amps clip hpupo Tubes / Valves 24 20th May 2011 02:24 PM
songs which cause your amps to clip perfusionist Solid State 10 17th May 2004 11:27 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
