PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
porting a compression driver enclosure
Old 17th October 2019, 08:29 AM   #21
Damo s is offline Damo s  United Kingdom
The port will provide some ventilation for when the driver gets hots, plus I found that when simulating a sealed enclosure even at 50 liters the response drops by more than 3db at the xover point compared with the ported 25 liter box.
Old 17th October 2019, 07:18 PM   #22
conanski is offline conanski  Canada
What are you simulating response with? The common reflex/sealed box simulating programs do not work with any accuracy above about 200hz.
Old 18th October 2019, 08:16 AM   #23
winISD. It's the region below 200hz that I care most about. A bit of EQ above that to flatten the response out isnt a major concern, but If I had to say boost 3db at 110hz to restore the punch then that's potentially going to consume a lot of power.
Old 19th October 2019, 04:19 PM   #24
OK you confused me with this talk of a dip at the crossover frequency as I thought this thread was about the compression driver not the midbass.
3 things:
Yes a sealed box rolls off sooner than a ported box but the bass/subbass crossover often ends up acoustically overlapped with the bass boost now common in modern music and with the way most people end up configuring a system with subs louder
The type of crossover used will also affect response through the crossover region, an even order LR will sum flat while a Butterworth produces a hump, designers sometimes use that to produce the desired response.
Modeling programs are based on mathematical formula and represent an ideal. The problem is drivers do not behave ideally and when they are combined with crossover and EQ filters the actual results you get will vary sometimes significantly from the simulation. If your speaker measures with roughly the same response shape as your simulation that is considered a success.
Old 20th October 2019, 05:22 PM   #25
yeah sorry it moved on to porting the mid / bass driver too.
I guess Ill find out once its made. hope it will be OK but expecting some EQ
Old 20th October 2019, 10:25 PM   #26
Don't worry about needing some EQ it's not really optional with PA speakers.
porting a compression driver enclosureHide this!Advertise here!
Porting for Small Enclosure clengman Full Range 18 17th February 2016 01:10 AM
Advice for enclosure volume, driver size and porting? DIY coffee table subwoofer ciper Subwoofers 8 21st May 2012 02:38 AM
Porting my sealed Enclosure KettermanJ Car Audio 1 7th November 2007 12:45 AM
Porting a fullrange enclosure? HiggityHank Full Range 20 10th December 2003 08:04 PM
Copyright ©1999-2019 diyAudio
