Pano, I see that you've been doing these mods for quite a while...
When you say "transformer only" outputs, what are you bypassing?
Or just putting a transformer on the line out? Do you recommend a particular model of transformer?
Regarding the PSU, what did you do?
Thanks!
Thanks!
Sorry I missed your post - been a little busy.
With the transformer out all active parts after the DAC chip are bypassed. The transformer is connected directly to the DAC output. IIRC, the AKM chips are specified for a 1K ohm load, but I don't load them that heavily. I usually put 3K-5K across the secondary of the transformer and let the next device in line provide the rest of the load.
I have used Edcor, Jensen, Cinemag and Onetics line level transformers. All of them good. There have been other brands I didn't like. The Jensen and Cinemag are easy to get and sound great. Typically I use a 1:1 ratio, but have also done 1:1.4 and 1:2 step up. You can use smaller transformers on the mids and highs, save the big ones for the bass.
I am connecting the DEQ to the DCX like bob4 has suggested. So I need input for the DEQ and output for the DCX. That Kappa board looks nice, but I'd need two build two of them, one for each unit, although I guess I could just leave the input components off one and the output off the other. On further reflection, I'm not even sure I can use the Kappa board with the DEQ. (BesPav, do you know how much all the components for the Kappa board would cost anyway?)
I think I might try the transformer output for the DCX. It's simple (but not inexpensive!)
So that leaves me hanging for the input to the DEQ. There is an input board mod from behringermods.com but it says it can only accepts a 2V input. I don't know what would happen if it were overdriven, as happens often when someone else is in control of the master on the mixer! The Behringer stock input can accept much higher levels.
Maybe I should just be looking for an ADC to put in front of the DEQ. This looks like it would do everything I need. Also not inexpensive but I am realizing there no free lunch.
Any thoughts?
Any thoughts?
You are correct that there is no free lunch.
I've made analog input boars for the DCX but always used the DEQ in digital mode. The input boards weren't complex, just some opamps in basic layout. The ADC inside the Behringer needs a low impedance to drive it. Also need to be differential. If you are coming in hot from a mixing console, you'll need some attenuation.
So I bit the bullet and ordered some Cinemag output transformers. (unfortunately I'll need to wait a month while they build them)
I opened up the DCX enclosure and realized that I'll need to pull out the entire analog I/O board...
Question: Do I need to do anything to the incoming AES signal from the DEQ? Or just pass it to the DSP board? It is accepted on the analog input "A" so I'm guessing it would normally be going through the input stage circuitry.
Little late to this thread, but I installed a set of Behringer Mods output cards on my DCX, and it has never sounded better (AES/EBU in from a DEQ upstream). Have a listen:
Bill Fitzmaurice SLA Pro Test 5 - YouTube
- Live Sound
- PA Systems
- Behringer DEQ/DCX mods at pro line levels?
