PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Custom Build Mixing Console
Old 21st March 2019, 08:18 PM   #11
Dolmetscher007 is offline Dolmetscher007
This is maybe the coolest thing I've ever seen!
Old 23rd March 2019, 08:41 AM   #12
Tarzan is offline Tarzan  Belgium
Tarzan's Avatar
I'm speechless.
This is just marvelous.
Excellent job!
Old 25th March 2019, 12:52 PM   #13
malibutwins is offline malibutwins  United States
Wow! This build needs to be in a magazine.
Old 25th March 2019, 07:58 PM   #14
ViennaTom is offline ViennaTom
Sorry if this question sounds stupid - but why does a console (that consists of a few small signal circuits and OPAMPS) need that size power suply?
Old 26th March 2019, 12:23 AM   #15
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
"A few"?
I expect 100 to 200 Op Amps there, auxiliary circuits, 600 ohm capable line drivers, headphone out, VU drivers, lamps, etc.
Start adding up
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 26th March 2019, 01:02 AM   #16
Vintage Audio Projec is offline Vintage Audio Projec
That is a good question.
The outputs are based around the neve Class A output using a transformer and drawing around 80mA minimum.
There are 2 of those for 1 channel (It is an inline console so you have one preamp with an output that goes to TAPE/DAW/.... and you have a return that also has an output that goes to the mixbuss. So that is 160mA of continous current draw (+24v). Most of the circuits is discrete. Only the balanced insert points use more modern THAT driver/receivers. These drivers als also capable of driving 600ohms.
So add the preamp and signal led circuits and you need a minimum of 200mA continous current for 1 channel (+24) If you drive 600ohm loads on the inserts etc you need around 500mA of current available. For 32 channels that is 16A or around 350w only for the +24v You also need -24v for the that drivers/receivers etc... we made the +24/-24 the same as it was the easiest thing.
So you see it really starts to add up. and I didn't start on the switch leds etc....
Also it is best to have a power supply that can do the job easily and dn't have to worry about it.
Old 26th March 2019, 09:48 AM   #17
turk 182 is offline turk 182  Canada
here's a supply for a PM3000 and when touring there's usually a spare mounted in the same rack making it a nice hefty weight...
Old 26th March 2019, 04:53 PM   #18
Damo s is offline Damo s  United Kingdom
what he said ^
Old 26th March 2019, 05:32 PM   #19
rtpburnsville is offline rtpburnsville
Very Nice!
Old 30th March 2019, 10:37 PM   #20
OK I see. My impression was that OPAMPS in consoles usually get +/ - 15VDC, right?
Anyway, your power supply looks like 3 KW+ to me.
Custom Build Mixing ConsoleHide this!Advertise here!
Help with a mixing console. Please.. JoeCFC88 Everything Else 2 18th November 2014 04:06 PM
SMPS for Mixing Console gruni Power Supplies 0 20th May 2013 09:06 AM
TAC Scorpion II mixing console PhantomBox Everything Else 1 23rd June 2011 08:16 PM
Tube mixing console Ronnie4416 Instruments and Amps 9 11th April 2011 11:47 AM
mixing console bus bar argonrepublic Parts 5 7th June 2005 04:17 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
