PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Design suggestions with PA drivers-For PA use (small terrace parties):)
Old 5th March 2019, 04:32 AM   #1
prasi is offline prasi  India
prasi's Avatar
Default Design suggestions with PA drivers-For PA use (small terrace parties):)
Hello All,
I am looking to design a stereo set of PA speakers utilizing PA drivers as per attached spec sheet. Its all I have. There is also a cross over available from the manufacturer specifically designed for the combination of these two drivers.
Since I have limited / no experience, could some one suggest a speaker design (closed/vented, port dimensions, cab size (volume), etc.
regards
Prasi
My revamped site https://sites.google.com/site/analogdesign1234/
Old 5th March 2019, 07:23 AM   #2
chris661 is offline chris661  United Kingdom
chris661's Avatar
What do you have in the way of amplification and signal processing?
The 12"s will want a large ported box to put out any bass, and the crossover from the 12" to the HF horn is going to be difficult. The HF horn wants to run from 3kHz (preferably 4kHz) upwards, while the woofer is already getting pretty rough up there.
Do you have access to any other drivers?
Chris
My work: www.grimshawaudio.com
Old 5th March 2019, 07:43 AM   #3
prasi's Avatar
Thank you Chris,
I have access to these other drivers.
1. http://www.ahujaradios.co.in/Documen...12-X100_SP.pdf
2. http://www.ahujaradios.co.in/Documen...12FRX-Z_OM.pdf
do you think any of these would work better with intended horn?
Prasi
Old 5th March 2019, 07:49 AM   #4
prasi's Avatar
For amplification, there is 200W PA amplifier that has mic, line inputs. Pretty basic stuff. Just does its job to play music and make announcements, etc.
Old 5th March 2019, 09:12 AM   #5
chris661's Avatar
The full-range driver looks better, but definitely isn't optimised for low-frequency output.
Do you want it to be very loud and/or have lots of bass?
I'm thinking you could do 2x full-range 12"s in one box, and put a big inductor in series with the bottom one.
Quality would be reasonable, and there'd be a useful amount of "thump" in the 70-100Hz region, even if it won't get particularly low.
Chris
Old 5th March 2019, 10:26 AM   #6
prasi's Avatar
Its an open terrace and audience will be about 60-80 nos.
Indians (general public) do like it loud and lots of thumping bass for bollywood songs.
They wouldn't care for "Hi-Fi" as long as its loud and with lots of bass. Amplifier has tone controls, so it will probably be turned all the way up for bass and treble
I dont know if the full range will produce enough bass because of its small Xmax.
Old 5th March 2019, 12:51 PM   #7
prasi's Avatar
would this one be more suitable with the horn driver of post 1?
http://www.ahujaradios.co.in/Documen...2-MB300_OM.pdf
Old 5th March 2019, 01:23 PM   #8
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Then use the most powerful, largest magnet, largest voice coil, most overhang of them, it being the L12MB200.
All suggest some kind of enclosure except that one, do you have size/weight limitations?
Do you need to carry it everywhere in a car or station wagon?
If not, as suggested above build a large cabinet, somebody around will certainly simulate and suggest dimensions and tuning for that woofer based on datasheet TS parameters.
Or ask Ahuja for a suggested cabinet for that speaker.
I am more worried about the tweeter, you will blow it to pieces the moment your amp reaches clipping which will happen 15 minutes into the the Party.
I suggest you use a typical auxiliary car lamp in series with tweeter, *after* the crossover output, 12V 15W is a popular value.
Oh PLEASE DONīT .
Donīt push into speakers frequencies thy clearly can not handle.
You-canīt-beat-Physics.
As soon as you can, build an extra pair of cabinets and drive them with another 200W power amp.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 5th March 2019, 01:47 PM   #9
prasi's Avatar
Oh, sorry, I should have been more clear. I plan to build these speakers for the housing society where I live. So I will never have any controls on how its used/abused.
I have written to the Ahuja, but no reply.
size shouldn't matter I think(width or height wise), but weight would better be limited to about ~30 kg.
I will try simulate the L12 MB 300, in a 70 to 80 liter ported cabinet.
What function the 12V car lamp do, I mean how does it help in protecting the tweeter?
Prasi
Old 5th March 2019, 02:52 PM   #10
prasi's Avatar
Here is a quick check of the ported box alignment in Unibox and box dimensions in Boxycad.
The woofer is http://www.ahujaradios.co.in/Documen...2-MB300_OM.pdf
The volume of box is 70 liters tuned to 45Hz. Weight becomes 20kg with 3/4" material and some bracing.
Adding driver weights (~10kg for woofer +horn), the total weight becomes nearly 30kg per box. Two people would be needed to move!
Design suggestions with PA drivers-For PA use (small terrace parties):)Hide this!Advertise here!
3 way Pa Horn Speakers for small parties. altsouza PA Systems 4 28th November 2014 05:24 PM
Drivers suggestions - small closed box Telstar Subwoofers 14 6th April 2014 03:39 AM
Please offer suggestions for small subwoofer (design, driver, amp) crossride Subwoofers 8 4th January 2013 10:07 AM
Small 2" drivers in BIB design Gugi Full Range 22 16th February 2011 06:01 PM
Loudspeaker for open terrace -suggestions. swak Multi-Way 0 27th August 2007 05:40 PM
Copyright ©1999-2019 diyAudio
