PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Behringer NU6000 - Reverse Fan Direction?
Old 15th November 2018, 05:11 PM   #31
TBTL is offline TBTL  Germany
Someone has already tried reversing the fan and measured temperatures on a NU6000DSP: https://www.avsforum.com/forum/155-d...n-results.html
The fan is not stock, it is a low noise one. The amplifier mosfets do not care about the direction, though a small component of the power supply prefers front-to-back.
Old 15th November 2018, 08:37 PM   #32
ViennaTom is offline ViennaTom
I did reverse airflow on iNU6KDSP and changed from 4000rpm to low noise arctic f8 2000rpm:
Result: ~ 2 x 800W into 8 Ohms, both channels driven, continuously.
Old 16th November 2018, 10:00 AM   #33
chris661 is offline chris661  United Kingdom
chris661's Avatar
Originally Posted by TBTL View Post
Someone has already tried reversing the fan and measured temperatures on a NU6000DSP: Inuke nu6000DSP fan direction results - AVS Forum | Home Theater Discussions And Reviews
That's some great info!
Thanks for digging that out.
Once the new (front-to-back) amps arrive, I'll swap the Behringer amps so they're compatible.
Thanks again!
Chris
My work: www.grimshawaudio.com
Behringer NU6000 - Reverse Fan Direction?Hide this!Advertise here!
How is Behringer NU6000 delivering 1500RMS into 8ohms with IRS2092s? rhythmsandy Class D 14 8th November 2017 08:40 PM
Behringer iNuke NU6000 Clipping sahar540 PA Systems 13 25th May 2017 08:05 PM
Using only one channel on the Behringer iNuke NU6000 Rullknufs Class D 10 7th May 2016 10:23 PM
FS: Behringer B2031A Pair (Some say they beat Orion!) and Behringer DCX2496 bmwparts Swap Meet 10 17th December 2014 02:58 PM
Man am I new and in need of direction SPLAudioHz Introductions 3 14th August 2011 06:00 AM
