PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Mic, Line, EQ... Preamps
Old 15th February 2020, 06:40 AM   #651
still4given is offline still4given  United States
still4given's Avatar
Found a mistake. Safety diodes at the input were not connected. This should be better.
Old 15th February 2020, 04:34 PM   #652
karachay is offline karachay
Originally Posted by still4given View Post
Please check this one over. If it is OK I can post PDFs.
hi mr. terry thank you for helping. i mark some fault on picture some lines not connected and 1 diode wrong polarity.
i was start drawing too on coreldraw. i will send when its finish.
Old 15th February 2020, 06:58 PM   #653
Thanks. I got too tired to check everything against the schematic. I'll fix the things you found and finish checking.
Old 16th February 2020, 01:24 AM   #654
I thinks one looks better. Please check it for errors and I will post PDFs for etching if you would like.
Old 16th February 2020, 03:12 AM   #655
PCB size: 260x95mm,
i just change some lines distances. i have coreldraw file too if any one want.
Old 16th February 2020, 03:14 AM   #656
thankyou mr. terry. and if you remember any changes abouth amp pls send notes. ty soo much.
Old 16th February 2020, 03:22 AM   #657
Originally Posted by karachay View Post
PCB size: 260x95mm,
That image will only work for Photo etch. If you want to do iron transfer you will need to reverse it. The name is reversed in your image
Old 16th February 2020, 11:39 AM   #658
thankyou mr. Terry.
can i have pdf for print? i will make yours.
this is right i think. i want to ask another thing. if i add reverb tank where is the best place for taking signal. after u1 or u2.
thank you soo much.
Old 17th February 2020, 01:33 AM   #659
Here are PDFs for Iron transfer.
I think you would take the reverb tank from the EFX Send and then return to the EFX Return.
Old 17th February 2020, 01:55 AM   #660
Here's mine.
Mic, Line, EQ... PreampsHide this!Advertise here!
help with single supply for two EQ/preamps lassoharp Power Supplies 3 9th July 2009 04:24 PM
HELP with PHONO and MIC preamps. P Lazkao Tubes / Valves 10 23rd June 2006 02:42 PM
measurement programs, mics and mic preamps. j.burtt Multi-Way 11 15th November 2005 09:08 PM
Power supplies in mic tube preamps JamMan Tubes / Valves 5 2nd November 2004 03:48 PM
mic preamps travis Solid State 7 20th May 2002 06:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
