The "Elsinore Project" Thread
Old 11th September 2019, 11:52 AM   #2541
a007udio is offline a007udio  Europe
What is the correct way to mount the tweeter in the enclosure?
Is the tweeter mounted on the waveguide and then on the enclusure or they are mounted separately?
Thanks.
Old 11th September 2019, 03:28 PM   #2542
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
Thanks.
Do not mount separately. Mount the tweeter to the waveguide and then mount it, waveguide and tweeter together, as a single unit into the enclosure.
"Elsinore Project" DIY Speaker System
- "Don't take anything I say as an affirmation, but as a question." Niels Bohr [i.e. be humble]
Old 11th September 2019, 05:20 PM   #2543
Ok, thanks to clarify.
But then i need to do room for screws on tweeter place. am i right, i didn't see those on others speaker constructions pictures.
Old 14th September 2019, 08:01 AM   #2544
OZmOZis is offline OZmOZis  Australia
OZmOZis's Avatar
Correct. You will need to make recesses for the nuts holding the wave guides to the speakers
Old 24th September 2019, 06:05 PM   #2545
dmcgown is online now dmcgown  United States
Default Update on Construction
Making great progress over the past couple of weekends. Enclosures are taking shape and soon should in the prep stage prior to applying finish (paint, though thinking about veneer at this stage).
As one might see, using biscuit jointery to assemble the butt joints, except for the main brace where it is a bit more difficult to use the jointer, so just screwed and glued in place from the inside to avoid having to patch external screw holes. Also trying to avoid splitting MDF. I still have a little misalignment of the baffle to the side panels, the baffle is perhaps 0.2-0.3mm or so beyond the edge of the side panels (an artifact of the slop between the jointer in the vertical vs horizontal orientation when cutting the slots for the biscuits). If it was the other way it would be easier (planing/sanding down the edge) however now I need to patch and built back up the panel edge. Bondo time.
Used a neat T-nut insert designed for hardwoods for the driver mounting holes. These have short anti-rotation barbs on the barrel of the T-nut rather than spikes on the flange. Drilled out the holes to the barrel diameter, applied a bit of glue (slow setting Superglue cement) on the T-nut flange and drove them home. No splits. These do not need as large of a hole than other nut inserts, and are steel rather than zinc or brass.
David
Old 24th September 2019, 09:02 PM   #2546
Quattrofish is offline Quattrofish  United States
Originally Posted by dmcgown View Post
Making great progress over the past couple of weekends......
David
Looks like they are coming together nicely.
I hope a locals listening session is part of your plan!
Old 25th September 2019, 12:10 AM   #2547
zman01 is offline zman01  Bangladesh
dmcgown,
That is good progress with the cabinets, keep us posted.
Old 25th September 2019, 01:32 AM   #2548
Definitely part of my plan!
David
Old 26th September 2019, 12:37 PM   #2549
Default More Progress
I had a little time yesterday, so glued the top and bottom on the enclosures. I made clamp extenders out of scrap MDF which were very helpful in gluing the ends on. Also, I added the damping insulation in the back corners at this time, since I figure it is easier to install with the enclosure still open. Used 1" thick bonded Dacron batting that is normally used for upholstery. It was sold as 1-1/2 to 2" thick, but the thickness was actually slightly over 1". Will see how it works.
Old 26th September 2019, 12:59 PM   #2550
Smart work with the clamp extenders.
The "Elsinore Project" ThreadHide this!Advertise here!
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 12:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
Copyright ©1999-2019 diyAudio
