Monacor SPH-165KEP + DT-25N DIY project
Monacor SPH-165KEP + DT-25N DIY project Please consider donating to help us continue to serve you.
Old 26th October 2006, 08:43 PM   #11
lovechild is offline lovechild  Europe
Hi Iggy,
if it needs to be Monacor, I can recommand this design here. It's very well documented, with lots of messurements, xover and all.
The designer will most certainly awnser questions via email in english.
or post your questions here in the Forum thread, I'll be there every once in a while and may help with translation if needed.
best, LC
Old 27th October 2006, 05:43 PM   #12
iggy888 is offline iggy888  Croatia
iggy888's Avatar
Thanx for all the advices. This is my first (but not the last) DIY speaker. I wanted to start with something cheap and easy to build. Drivers are now here and playing in free air. Promising! I have Wh. Diamonds 8.3 and I hope (and think) that these speakers will sound a class above them. My next project will probably be something more demanding, like ProAc R. 2.5 clone, so there are Scan-Speaks. They can be bought in Croatia and I already asked for the price. Greetings to Split!
Old 30th October 2006, 05:50 PM   #13
iggy888's Avatar
Could anyone tell me will I have a problem with baffle step compensation on this project http://jan-jaap.vegter.nu/bs.html. I don't know how to calculate it and how to fix it, if it is necessary. If someone could help me and tell me what to do I would be grateful. I don't know is it normal that, when I play them in free air, the drivers appears to be too ''bright'' (too much high frequencies). I would like to know what to do ASAP 'cause the boxes are nearly finished. Thank you very much.
Old 30th October 2006, 06:06 PM   #14
R.I.P.
the crossover has very high attenuation of the tweeter, 6.8R in
series and 3.3 in parallel ~ 12dB of attenuation, if they are still
too bright with this I'm not sure whats going on.
With 95dB/W = 83dB/W which indicates the speaker has BSC.
/sreten.
Old 30th October 2006, 07:18 PM   #15
iggy888's Avatar
Thank you. Maybe it will sound different when it's all done and in proper position. We'll see in a week or two. Thanx again.
Old 31st October 2006, 10:40 AM   #16
Maxi is offline Maxi  Poland
Hi
I have sph165kep and vifa xt19td. They play very well
The Monacor sph165kep is a good speaker. In a small box they play very good - small box 20liter's :P
Look this:
http://audiomania.info/forum/viewtopic.php?t=3014
About sph165cp:
this speaker don't get down like sph165kep. They play more "hard".
Sorry about my language
Old 31st October 2006, 11:06 AM   #17
R.I.P.
Note that out of a box the bass/mid unit will have no bass at all.
/sreten.
Old 31st October 2006, 04:47 PM   #18
iggy888's Avatar
/sreten.
Thanx, I'm aware of that. Anyway, soon they will be finished and we'll see the result. I'll keep you posted. I'll put some photos here after the job is done.
Old 31st October 2006, 07:17 PM   #19
Vedo is offline Vedo  Croatia
Originally posted by Maxi
Hi
Look this:
About sph165cp:
Excellent work,Maxi!
Old 31st October 2006, 08:18 PM   #20
Sorry this aren't my speakers. My friend "Seweryn" created this loudspeakers
Monacor SPH-165KEP + DT-25N DIY projectHide this!Advertise here!
Q:monacor sph-165kep Tomac Multi-Way 47 14th February 2015 07:45 PM
Monacor SPH-165KEP on Ebay gaborbela Swap Meet 0 19th January 2008 02:15 PM
Peerless HDS 180 EXC vs. Monacor SPH-165Kep MarcinM Multi-Way 2 5th July 2006 03:16 PM
good or bad idea -- monacor SPH-165KEP qubix Multi-Way 35 12th January 2005 03:45 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
