Suitable midrange cone, for bandpass mid in Unity horn.
Old 16th February 2019, 01:55 PM   #2251
njones is offline njones  United States
Originally Posted by njones View Post
Sprayed the back side to protect from wet sanding. It was quite a bit of work to add the filler circles but hopefully results in smoother response with more extension.
The attachment did not upload, trying again.
Old 16th February 2019, 02:03 PM   #2252
nc535 is offline nc535
Originally Posted by kees52 View Post
Hi Guys
Sorry I hijacking afcourse not mine attemption to do so
I think I did post earlier but have a question, because I want to use the synergy in a home size matters, I have sim with just one bass speaker and one mid, is this possible and where I have to place the port then? bassrereflex pipe can replace the other speaker?, normally there are two speakers and 4 mids, but maybe one bass and two mid is a better option for me.
I have seen unity's who has a wideband speaker of 3 inch in stead of the compression driver with only a bass, the wideband does all from 400 a 600 hz or so and higher, but I think it will fall off 6 dB octave I can correct that but loose a lot of efficienty.
The old phillips woofer of 42 years old do quite well here.
thanks.
BWaslo's small syns uses just one mid. He argues (convincingly) that provides enough SPL for home use. You can put the ports anywhere you want, so long as they are the correct distance from the throat, but I would still put each hole in or near a corner if its a rectangular horn.
My Synergy Corner Horns and Bass Bins
http://www.diyaudio.com/forums/multi...bass-bins.html
Suitable midrange cone, for bandpass mid in Unity horn.Hide this!Advertise here!
Bandpass Woofer/Midrange? m@ Multi-Way 5 25th March 2006 02:10 AM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 05:06 AM
Copyright ©1999-2019 diyAudio
