ARTA
ARTA
Old 23rd May 2019, 02:18 AM   #811
BYRTT is offline BYRTT  Denmark
BYRTT's Avatar
ARTA
Originally Posted by Zung View Post
How do you do this?
I've tried their beta driver with Windows 7, 8, 10 over the years, NO success. Last time with Windows 10, it frozen the PC solid.
Just curious, the E-MU went to a closet, and I've been living happily with a Focusrite Scarlett.
I can't know if procedure will work for your brand but can say below method works for other brands that only support older driver packages for their hardware devices be it sound cards or whatever devices where driver came packed into one EXE file.
In general Win7/8/10 supports using a driver package down from WinVista and up so pick the latest one relative to your running system and run it in combability mode, example is say you have a WinVista driver package that should run on Win10 then don't run it out of the blue but rightclick EXE file pick properties and in compability tab set settings so that it run as WinVista mode and push Okay, now one can run the installation. Some packages install some permanent procces that run in background and to get those run in compability mode open taskmanager and look for procces that belong to hardware then rightclick pick properties and in compability tab set to WinVista mode and push Okay.
Old 24th May 2019, 11:46 AM   #812
Denri is offline Denri  Russian Federation
How do you do this?
Zung, some users reported problems about E-MU0202 USB and Win7 . I saw several discussions with at least 50% success of working cards. Most time people solved issues by flashing different versiosn of firmware even stock one.
I had lastest firmware and clean MSDN Windows 7 SP1 without updates as in my system due some issues with OS as updates could not be installed and I'm lazy to reinstall OS.
I used EMUU_PCAppDrv_US_1_40_00_BETA.exe as driver package. Other versions did not tried.
The only issue I have as sometimes sound may disappear in all applications while card in steady state(I am not alone with this). if it plays something - no issues. So nothing special here , only luck
Old 5th June 2019, 10:09 PM   #813
altie is offline altie  United States
I need to double check an assumption: if I'm measuring directivity of a horn, I would rotate around the mouth, right? That seems like the axis that wouldn't introduce any incorrect differences in distance but I'd like to check that before I waste time on invalid measurements.
Old 6th June 2019, 08:40 AM   #814
kimmosto is offline kimmosto  Finland
kimmosto's Avatar
Yes, that's the safest rotation center no matter are you measuring in single or dual channel connection and mode.
Reflections could disturb automatic detection of impulse peak in single channel measurement mode. Positioning error usually happens to off-axis angles >120 deg. That shouldn't be a problem if you measure 0-90 deg only. Dual channel mode locks timing so starting point of time window stays where you have set it up to 180 deg off-axis so no need to adjust time window and export response of all measurements separately.
Old 14th June 2019, 08:18 AM   #815
DennyG is offline DennyG  Australia
ARTA
Default Audio Interface with acceptable dynamic range and cross-talk
Originally Posted by iMat View Post
You are not wrong.
When there is small replica of distorted antialiasng filter response, it is in 99% cases result of high cross-talk between left and right input channels. Some converters are really bad in this sense, i.e. Behringer UC202, or motherboard systems.
In ARTA user manual (chapter 4.2) I have described how to test soundcard dynamic range and cross-talk.
If your soundcard has large cross-talk you should use single channel measurements, but the problem remains when you measure impedance.
Ivo
P.S. You may get some IR replicas when measuring with clipped swept sine.
My USB audio interface also has the replica pulse at -2 to -3 mS so I'm looking for a USB Audio Interface with acceptable dynamic range and cross-talk for use with ARTA.
The ARTA site gives an extensive list of interfaces but they range in price from very reasonable to expensive.
The specifications on some devices I've looked at rarely quote a figure for cross-talk and only state one value for dynamic range without specifying the frequency. The ARTA-Manual tests on my USB interface show some similar results to those in the ARTA-Manual for low cost sound card SC1 but quote in the specification a value for dynamic range of "107 db (A Weighted)" so what to believe?
Has anyone with a USB interface done the ARTA tests and found their interface has acceptable results like for those shown for the RME BabyFace Pro. The RME is some 5 times the price of some of the other units listed on the ARTA site like the inexpensive, popular, readily available devices such as Tascam US2x2, Roland Quad Capture, Scarlett 2i2, Steinberg UR 22 MkII to name some reasonably priced basic interfaces.
Old 18th June 2019, 02:08 AM   #816
Turbowatch2 is online now Turbowatch2  Germany
One can easily become obsessed with 100dB and more noise´n stuff. In reality you should define what you want to measure with ARTA, before discarding sound cards or build in sound chips. For many applications like loudspeaker measurement there are many links weaker than even a cheap netbook soundcard chip. If you don´t measure in a special location, any sourounding noise will be more present than the internal.
If you want to measure amps and DAC´s things get more complicated, but ask youself: "Can I do anything about the measured data". If you are an audio developer, there may be some more professionel stuff around, but you would know. If you just measure for fun, it is a hobby and you can spent as much as you like or not. There are surprisingly good soundcards around, at eBay sometime for something like 12$ or even less. Because of the multi chanel hype some stereo or low channel models have lost any value. If you use a desktop, consider Creative Soundblaster cards. They are as low noise as advertised and dead cheap. Maybe use external USB for mobile measurements and a desktop for high quality stuff. Or pay the price...
Old 18th June 2019, 03:19 PM   #817
PRTG is offline PRTG  Latvia
PRTG's Avatar
ARTA
Thanks for highlighting these, ScottG.
I aimed for something that can trustworthy measure up to 30K to see if there are any artifacts appearing above 20K which could be a sign of caution. And high undistorted SPL tolerance for THD measurements of high output testing levels. So I'm still quietly thankful to someone who recommended it here years ago. But I know there should be less expensive alternatives lying around somewhere.
Regarding el-cheapo & time consuming DIY mic exercises - any experience with Linkwitz Panasonic capsule mod and preamp circuit? I've searched and read descriptions of some build attempts, and they were controversial.
Originally Posted by ScottG View Post
..at less than half the price:
EMX-7150 Measurement microphone (bulk) - iSEMcon_US
-and you could probably get an even better calibration file for it (..maybe from Cross-Spectrum).
Speaking of Cross-Spectrum, they carry MicW ..if you really wanted to spend as *much as the Earthworks mic., you could ask Cross-Spectrum about getting a M215 from them with their additional higher quality calibration.
Cross·Spectrum - Calibrated MicW i436 Microphones for Sale
MicW
*actually it should still be less.
Old 18th June 2019, 09:44 PM   #818
ScottG is offline ScottG  United States
I think all my really cheap mic.s have the Panasonic capsule.. or some version/copy of it.
I've not tried the Linkwitz mod.. Isn't it a voltage-to-current operation change? If so that usually results in a much lower noise result, but that's probably the only change unless there is an inductive rise from the capsule at just the right range (20-100 kHz): which I doubt there is. Who knows though, the change in amplifier might simply allow it to extend much higher in freq.. Even then though, you still have no idea of linearity.
Basically the least expensive Mic's I've seen that are of the 40 kHz -3db with calibration are from Earthworks.. and at that price I'd start looking hard at spending more for an ACO Pacific reference. My guess is that calibration (full bandwidth file) services that go beyond 20-25 kHz are expensive as well.
A calibrated MEMS capsule would be ideal for this (cheap + high freq.), don't know of any though.. Of course all MEMS are "calibrated" so you might be able to do an inversion response to linearize it assuming you had the original response (though as seen below, it's just a "typical" response):
https://www.zachpoff.com/site/wp-con...-Note-AN17.pdf
perspective is everything
Old 21st June 2019, 10:09 AM   #819
rich08 is offline rich08  Slovakia
Originally Posted by ente View Post
Hi Rich08,
yes it's the terminal voltage (original manual, fig 3.1 or 3.2, left in).
The following pic shows max THD (as defined in original Manual on page 25 "a) Procedure in Stepped sine mode") as function of terminal voltage for 3 different drivers.
Heinrich
Heinrich, what high value of THD is still good or which is ideal?
Thank you
Old 17th July 2019, 09:15 PM   #820
jzagaja is offline jzagaja  Poland
ARTA
In attachment I send you simple impedance jig that enables impedance measurement without power amplifier. Just use headphone output (RME outputs 3/4) as generator with reference resistor 47 ohms.
Use RME inputs 3 and 4 as unbalanced one.
Best,
Ivo
Works very well. Ref resistor 47R, 38R value in Limp to get proper reading. Is calibration necessary?
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
ARTAHide this!Advertise here!
Arta box. miklos Equipment & Tools 2 19th September 2014 07:27 PM
Help with Arta- HOLMImpulse viki_v2 Software Tools 2 12th September 2012 02:04 AM
arta vs cliowin ermes Multi-Way 0 4th March 2011 02:37 PM
ARTA - using ARTA to measure room acoustics! OMF Software Tools 0 25th November 2009 01:55 PM
ARTA help Cousin Billy Multi-Way 2 13th February 2009 12:16 AM
Copyright ©1999-2019 diyAudio
