ARTA
ARTA
Old 15th January 2017, 03:38 PM   #521
ente is offline ente  Germany
Default ARTA DIY-Turntable
... here you will find some more information about the turntable:
https://www.youtube.com/watch?v=FWQudBXWUZs
Heinrich
Old 15th January 2017, 08:50 PM   #522
Omholt is offline Omholt  Norway
Omholt's Avatar
ARTA
Originally Posted by ergo View Post
Seems that the PCB+controller is for sale here for 99EUR
ARTA Turntable
and the other items are also reasonable price - so would make a nice DIY project.
I have tried to contact him, but haven't received any reply. I'm interested in buying.
Old 15th January 2017, 09:56 PM   #523
Hi Bjorn,
I will inform Ralf about your attempt to contact him.
Here is some additional Information about the making of the DIY-Turntable:
Heinrich
Old 23rd January 2017, 07:05 PM   #524
GerardMan is offline GerardMan
My turntable version for ARTA is a 3D design to see when I can do it.
An externally hosted image should be here but it is no longer accessible. Please upload images instead of linking to them to prevent this.
Old 31st January 2017, 07:50 AM   #525
Omholt's Avatar
ARTA
How can I change the db scale on the Y-axis to higher resolution for the polar plot? In this example, -6 dB ends up being out of bounds.
File Type: jpg proto topphorn horisontalt 20 ms gating1.jpg (698.4 KB, 312 views)
Old 31st January 2017, 09:46 AM   #526
iMat is offline iMat  Croatia
the smallest range is 5dB which gives (color) resolution step of 0.5dB. You can adjust it with control "Range".
Allowing smaller range than this is not good as interpolation algorithm, and measurement itself, introduce some errors.
Best,
Ivo
Old 31st January 2017, 09:53 AM   #527
Omholt's Avatar
ARTA
Best,
Ivo
If I minimize the range, I don't get to see out to -6dB. So that doesn't help me much.
Is there no way to change to angle on y-axis only?
I would like to show it in similar way like this one where it's been used 80.
Old 31st January 2017, 04:52 PM   #528
Sorry,
I did not understood your question.
-6dB is meaningfull if you normalize responses.
Please make directivity plot again and normalize with response at zero angle.
Ivo
Old 31st January 2017, 05:41 PM   #529
Omholt's Avatar
ARTA
Sorry,
Ivo
Is it possible to change the angle on the y-axis? For this spesific measurement it's automatically using 40 degrees. I want to change it to 80 degrees.
You can see the setup I've used below and the result. It's not showing me enough. -6dB is outside the graph. If I reduce it to 10 db range, it's only showing till -4 dB.
Old 31st January 2017, 06:55 PM   #530
The angle range is determined by input data, i.e. name of files contain angle, and that input range can't be changed later.
Ivo
ARTAHide this!Advertise here!
Arta box. miklos Equipment & Tools 2 19th September 2014 07:27 PM
Help with Arta- HOLMImpulse viki_v2 Software Tools 2 12th September 2012 02:04 AM
arta vs cliowin ermes Multi-Way 0 4th March 2011 02:37 PM
ARTA - using ARTA to measure room acoustics! OMF Software Tools 0 25th November 2009 01:55 PM
ARTA help Cousin Billy Multi-Way 2 13th February 2009 12:16 AM
Copyright ©1999-2019 diyAudio
