series vs parallel SPL?
Old 20th February 2006, 06:02 PM   #11
MJK is offline MJK  United States
If you look under the General Speaker Related Articles page on my site you will find a short write-up about wiring two drivers in series or parallel along with a worked example that calculates the equivalent driver properties and the SPL resposne.
Old 20th February 2006, 06:15 PM   #12
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
The link to that short article is here.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 20th February 2006, 11:31 PM   #13
Lusso5 is offline Lusso5  United States
Lusso5's Avatar
Attached is a visual of (8) 16ohm drivers that are 100dB in two configurations to end up with 8ohm. The figures in the visual represent power conversion only (i.e 3db), but even if acoustical conversions are entered, you'll still arrive at 112dB for both.
Both configurations end up at 8ohm, but one group has 6 parallel groups, and one has 3 parallel groups.
Which configuration is more efficient?
Old 21st February 2006, 06:29 PM   #14
e-side is offline e-side  Netherlands
Originally posted by kelticwizard
Of course, since our 8 ohm somposite spekaer is an 8 ohmer, it will get only hald the power delivered to it that the 4 ohm single speaker will, so the SPL per 2.83 Volts will equal the 4 ohm speaker. Even though it is only drawing half the power. Because the the 8 ohm composite speaker is 3 db more sensitive per watt.
You're right, I'm wrong.
regards
Erwin
Old 21st February 2006, 08:53 PM   #15
vadi is offline vadi  Austria
vadi's Avatar
Hi!
Can I lower the SPL of a woofer by adding a resistor?
Sladjan
Old 22nd February 2006, 10:26 AM   #16
Probably yes, but adding a resistor in series with the woofer will change the parameters of the woofer (Qes and Qts).
When your woofer has, for example, the following parameters:
Re = 8
Qms=4
Qes=0,4
Qts = 0,36
When you wire a 4 ohm resistor in series with the woofer, I believe Qes and Qts change as follow:
Qes' = Qes(1+(resistor/Re)) = 0,4 (1+(4/8)) = 0,6
Qts' = (Qms . Qes') / (Qms + Qes') = (4 . 0,6) / (4 + 0,6) = 0,52
I'm not sure the above will happen when you wire a resistor in parallel with the woofer, but the impedance changes because of the resistor.
regards
Erwin
Old 22nd February 2006, 10:58 AM   #17
vadi's Avatar
Thank you very much e-side!
Sladjan
series vs parallel SPL?Hide this!Advertise here!
What would you do? series/parallel MtnBob Multi-Way 22 23rd August 2016 02:41 AM
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 38 20th February 2014 12:16 AM
series or parallel? medicman Tubes / Valves 5 22nd January 2009 05:42 PM
Series vs parallel? legendaryfrog Full Range 5 14th December 2006 03:50 PM
