How can I make this design more SQtastic (yes I made it up)
Old 2nd June 2005, 07:04 PM   #61
Audiophilenoob is offline Audiophilenoob  United States
Originally posted by johninCR
Only a line array will do that. That's why my cheapy arrays are in my workshop where I'm constantly moving around. Unless you get way off axis they sound the same. Plus I can play them at a good volume and they aren't super loud when I get up close.
so are you supporting the all out audiophile first design?
Old 2nd June 2005, 07:20 PM   #62
johninCR is offline johninCR  United States
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Yes and no. Since you are going active with EQ, then I would strongly suggest getting a sheet of plywood and ripping it in half lengthwise and trying the drivers OB first and give the woofers more line length.
Everyone has a photographic memory. It's just that most are out of film.
Old 2nd June 2005, 08:39 PM   #63
I will try OB first but in my setup I'm not sure it would be ideal... especially since it will be within 1-2 feet from the walls
Old 2nd June 2005, 08:55 PM   #64
Unlike boxes OB's can be tuned to meet your placement needs. A little rear wave attentuation usually is sufficient for placement near a rear wall. A layer of fiberfill batting covered by a single layer of 1/2" open cell foam rubber will probably do the trick. You may not even need it at all if you use a flat baffle. I've always used wings which results in a hollow sound when place near a rear wall and a little attenuation clears it right up.
Old 2nd June 2005, 08:59 PM   #65
what about a semi-circle OB?
you mean fiberfill and rubber directly over the rear?? like so that no part of the speaker inside can be seen but the waves will still escape?
or just fiberfill and foam on the baffle and wings?
Old 2nd June 2005, 09:05 PM   #66
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
My open baffles are just 180 hz and above, and flat.
They sound better and better until you get them about 5' from the wall, then the sound doesn't change. I would say your concerns might be justified.
I haven't tried the attenuation, but probably will. Also you can put similar stuff in panels put on the wall
"The geek shall inherit the earth"
2019 Burning Amp is Nov. 9 & 10 in S.F. Thread here on diyAudio:
Burning Amp 2019!!!
Old 2nd June 2005, 09:22 PM   #67
They sound better and better until you get them about 5' from the wall, so I would say your concerns might be justified.
cool... I didn't think about hanging sound panels... still not ideal though
Old 2nd June 2005, 09:34 PM   #68
I don't know what you mean by semi-circle, we're talking about a line array. The drivers need to face forward, so if you are talking about a curved baffle, the woofers would need to be a separate unit. Yes covering the drivers. Over the back of the drivers will be easier to tune to your liking and you don't have to make it pretty like something on the rear wall. Then cover the whole ugly mess with a speaker cloth like material after you get it tuned to your liking.
With what you are talking about, I'd only put enough wing for baffle rigidity and attach wires from the top to the ceiling, so they can't fall over and kill somebody. Paint the wires so they're virtually invisible.
Old 2nd June 2005, 10:09 PM   #69
thylantyr is offline thylantyr  United States
re: partial arrays
Here's a two word tip that went over everyones head.
Tilt
Rotate
Old 3rd June 2005, 12:05 AM   #70
Originally posted by thylantyr
re: partial arrays
Tilt
Rotate
Is that like the Bend & Snap ?
How can I make this design more SQtastic (yes I made it up)Hide this!Advertise here!
Made up a TL design... any comments ? Empee Multi-Way 74 25th July 2012 03:52 PM
Dipole design made easier rick57 Multi-Way 1 11th April 2007 06:54 PM
Let's make a CSS WR125 TL design dunderchief Multi-Way 0 29th December 2004 07:43 AM
How lucky are we? TJ type 50 triode to be made. Make your preferences known now! jusbe Tubes / Valves 3 16th July 2004 05:18 PM
Copyright ©1999-2019 diyAudio
