need more impact
need more impact
Thread Tools
Old 8th February 2005, 03:03 PM   #1
DIYGuy is offline DIYGuy  Canada
Post need more impact
Ok, I have a pair of Klispch Heresy and a 75lt DPL12 sub. I listened to a live band the other night and noticed quite a defference in the impact from the drums. I don't know what freq. the different drums are, but it seams the DPL12 is a little lower. This leads me to believe I need to look at the Heresy. I need something that can reproduce the higher bass freq. Or would a larger 15" sub do the job? maybe two
Old 8th February 2005, 03:14 PM   #2
richie00boy is offline richie00boy  United Kingdom
richie00boy's Avatar
Maybe it's not your speakers, but that fact that recordings are quite compressed and live bands usually are much more dynamic.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 8th February 2005, 03:14 PM   #3
pinkmouse is offline pinkmouse  Europe
diyAudio Moderator Emeritus
pinkmouse's Avatar
The FOH engineer probably just put a peak in at about 80-120Hz. Much easier just to build a little parametric EQ circuit to do that rather than rebuild/replace speakers.
“One of the poets, whose name I cannot recall, has a passage, which I am unable at the moment to remember, in one of his works, which for the time being has slipped my mind, which hits off admirably this age-old situation.”
― PG Wodehouse
Old 9th February 2005, 08:55 AM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
need more impact
Are your Herseys stock...on the ones i had the bass was really bad -- to a large extent a contribution of the back panel which is effectively a really bad passive radiator.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 9th February 2005, 09:52 AM   #5
Hennie is offline Hennie  South Africa
DIYGuy,
A bigger sub won't give you that live sound - changing to a new sub may improve matters, but that live sound will remain elusive with closed box speakers. Too much room induced ripple and too much indirect sound. Low efficiency subs also compress, taking the already compressed recording over the edge.
With good live recordings you can get pretty close though with the following recipe:
IB sub below the first room mode.
Huge high efficiency dipole sub and upper bass/lower midrange up to the Schroeder frequency of the room, low compression drivers. Preferably a matched constant directivity design further up the frequency band.
Horn fans may suggest a bass horn instead of the dipole. Its directivity and low compression will take you closer to live performance dynamics. Bill Fitzmaurice sells plans for relatively compact bass horns.
Too much indirect sound kills dynamics. You can try the follwing as remedy for a closed box setup:
Move the sub to a nearfield position if possible. This will reduce room induced ripple. EQ if necessary. Try to get more direct sound from the Klipsch too by moving it forward into the room and decreasing listening distance. I do not know the Klipsch - it may very well sound too bright close up. But try it, and if it gives you better results otherwise but sound too bright you can reduce the horn level.
How about:
Use the Adire below 35 - 40 Hz in a nearfield position. (Nearfield because it is probably just over the first room mode). EQ if necessary.
Build one of Fitzmaurice's compact subs from there up to 150 - 200 Hz.
Put the Klipsch drivers on an open baffle main panel and EQ as necessary.
Old 9th February 2005, 03:04 PM   #6
GM is offline GM  United States
GM's Avatar
This article explains what it takes to reproduce drums at a live level so get an expander to uncompress the recordings and scale this system's performance parameters to suit your desired peak average SPL/dynamic range based on your room/wallet limitations: http://www.scrounge.org/speak/burwen/index.html
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 10th February 2005, 06:52 AM   #7
HiFiNutNut is offline HiFiNutNut  Australia
From a different perspective, I found higher frequencies do impact on the perceptive impacts of the drums. I don't fully understand why and I hope someone can shed some lights on this.
I have tuned a pair of speakers to produce nice and sweet mid range sound. Female voices sounded superb. However, the drums were absolutely weak and messy when playing track 11 of Patricia Barber's Cafe Blue - there was nearly no definition of the drums. I increased the output from my active XO for frequencies below 200Hz and it did not help. I thought this was the compromise I must make in order to get the best mid range sound so I didn't try to fix the bass. 2 months later, interestingly, while I was doing some experiments with my XO all of a sudden I got very good drum sounds with that difficult sound track as well as with other music. This was what I did: I increased the baffle step compensation thus had a 1.5dB increase in the lower mid / bass range, and I actually tuned down the frequencies below 200Hz a bit, and at the same time increased about 1 to 1.5dB in the region from 1k to 6k. I thought it was the latter that made the drums come to life. The drums (and other LF music) were 10 times better, although the lower octave seemed to be gone. The accuracy of the mid range especially female voices did get degraded and the sound became a little bit harsher.
I am thinking that the bass would only create the atmosphere while the definition of a drum would still come from the higher frequencies. Therefore, the impact of the drums not only relies on LF but also HF as well.
Let me know if I am wrong.
Bill
Old 10th February 2005, 08:01 AM   #8
Bill your experience ties in with mine. This also applies to the off axis response. With a speaker like the Klipsch there will be a dip in the off axis response just below the crossover and this will contribute to the problem. Getting more direct sound will help to alleviate it in my perception.
  Reply to this post
need more impactHide this!Advertise here!
Thread Tools
bi-amping with sonic impact t amp/using sonic impact amp for headphones jon_m Class D 3 16th February 2006 11:16 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
