Old Scan-Speak tweeter
Old 4th November 2004, 10:38 PM   #1
Arthur-itis is offline Arthur-itis  United States
Default Old Scan-Speak tweeter
I have 4 of the old Scan-Speak 18W/8544's that I'd like to use in a kit that was designed by Joe D'Appolito, the Model 717s.
The tweeter that was originally used was the D-29, now no longer in production I am told.
I'm also told that the nearest thing to it and possibly a drop in replacement is the D2905/9300.
If anyone has the specs for the D-29 so I could compare them, I'd appreciate it very much.
Has anyonne here ever built this kit?
Comments on it's performance................
Thanks in advancefor any help.
Arthur
People who live in glass houses, should use the neighbor's bathroom.
Old 5th November 2004, 07:18 PM   #2
Jonasz is offline Jonasz  Sweden
Jonasz's Avatar
Thumbs up Specs
Hi Arthur...
If you mean the SS D2905/9000 ( the forerunner of the 9300) I have a couple of these tweeters and a bad copy of their specs on paper...
I've used these tweeters in this design intended for the 9300, wich worked fine btw. http://www.speakerbuilding.com/content/1021/
I've never heard the 9300 but compared to the 9500, 9700 and 9900 it lacks some detail and top end extension. I will scan the specs and email them to you during next week if you want to.
One pequliar thing about them is that the dome is sticky and a LOT of dust get caught...
Jonas
Old 5th November 2004, 07:31 PM   #3
markp is offline markp  United States
I've built the exact speaker you are thinking about! I love them. I used two 18w8544 and the D9500 tweeter in the MTM configuration. Make sure you include baffle step compensation in your crossover or it will be overly forward sounding. I'll post the pictures later when I get home.
If it sounds good... it is good!
Old 6th November 2004, 02:40 AM   #4
Jonas
I thought the sticky stuff was something particular to all their tweeters.
Yes, I would very much appreciate the specs if you can send them.
Thanks.
Old 6th November 2004, 02:53 AM   #5
[QUOTE][COLOR=blue]I've built the exact speaker you are thinking about! I love them. I used two 18w8544 and the D9500 tweeter in the MTM configuration. Make sure you include baffle step compensation in your crossover or it will be overly forward sounding. I'll post the pictures later when I get home.
The speakers I'm planning were sold by the old A&S Speakers up in Northern Claifornia. and were sold as a kit. The only designation in the schematic is D-29 for the tweeter.
The whole thing was desinged by Joe D'Appolito and operates as an 8 ohm load. External dimensions are 9.5 inches wide x 22inches high x 13 inces deep with a 7.5 inch long x 1.25 inch slot port.
In looking over the other paperwork I find the designation of the Tweeter was D2905.
Currently I'm using the 18w/8544's in a standard 2 way with a Focal tweeter crossed at 3kHz. I like the idea of the lower xover point of 2200 in the 717s.
Old 6th November 2004, 03:01 AM   #6
BrianL is offline BrianL  United States
I believe the tweeters in the Signature 717 are the xxxx-9200.
The -9300 version is, as I understand it, essentially the same
tweeter but with a non-stick coating on the dome. I believe
that Madisound's catalog once mentioned that they'd replace
the moving portions of a dead -9200 with the -9300 part.
So, I think for the 717 system that the two tweeters can
be considered interchangeable. I'd be somewhat careful
about using the newer, fancier S-S tweeters mentioned
above as they are not exactly the same in sensitivity and
roll-off.
I have a pair of these systems that I bought and they are
very nice but have very little bass. Everything checks out
dimensionally, but I think that maybe I overstuffed them.
It was never clear from the rather skimpy information that
A&S Loudspeakers generated exactly how much stuffing
one should use.
I should really get off my duff and un-stuff.
bel
Old 6th November 2004, 04:12 AM   #7
roll-off.
one should use.
The kit from A&S contained 1.5 Lb. of long hair wool, although I would never use the stuff since moths like it and Acousta-stuff or regular old polyester pillow stuffing works just as well.
As to bass I'm not worried my sub will take over very nicely for bass augmentation. Like all speaker builders, Im chasing that airy soundstage that I think will be improved witht he new tweeter and more suitable xover.
Not to worry, I would not use anything that didn't match in sensitivty unless I redisigned the xover, which is more than I want to tackle these days.
Old 7th November 2004, 02:55 AM   #8
JamesE is offline JamesE  United States
Mark,
I'm interested in building the same speakers that you built only using 18W8545-00. Would you post box dementions and xo's? Did you do a sealed design?
Old 8th November 2004, 12:07 AM   #9
After doing another search I found what I assume is an old webpage for Speaker City that has specs for older Scan-Speak drivers.
It looks to me like the 9000, 9300, or 9500 would all work equally well.
Thanks to everybody for their help.
That web page is http://www.speakercity.com/specs/scan_ts.shtml
Old 10th November 2004, 04:15 AM   #10
Arthur,
Any idea on how much Acousti-stuff is equiivalant to a certain
amount of wool? I actually tossed my wool before using and
bought Acousti-stuff. Same reason as you
The same weight of Acoustistuff gave me a huge
pile. I couldn't begin to stuff it all into my 717's,
but I still think I overstuffed.
bel
Old Scan-Speak tweeterHide this!Advertise here!
Scan Speak: old Revelator (9900) vs new neodimium tweeter danyele Multi-Way 3 30th October 2012 09:47 PM
Scan-Speak tweeter upgrade options? gfinlayson Multi-Way 13 9th June 2009 02:06 PM
Scan Speak 9500 tweeter + kids = tears zigzagflux Multi-Way 19 1st July 2007 05:29 AM
Selling 2 Scan Speak tweeter 95000 andy2 Swap Meet 2 13th August 2006 11:41 AM
WTB: Scan-Speak D2010-8513 tweeter genome Swap Meet 1 18th January 2006 01:46 AM
Copyright ©1999-2019 diyAudio
