Directivity of side by side woofers
Thread Tools
Old 25th November 2021, 12:00 PM   #41
tmuikku is offline tmuikku  Finland
Send a message via ICQ to tmuikku
Here is how to improve such system polars and directivity control (at least in the sim) as well as macho points, use three woofers! The middle one seems to even out some of the lobing around 1kHZ (if it mattered anyway) while increased c-c of the outer drives get directivity control down low.
That would make six woofers for a stereo system, should be plenty
Old 25th November 2021, 12:11 PM   #42
Robh3606 is online now Robh3606  United States
Robh3606's Avatar
Here are measured plots for a JBL 4838 twin 15 Cinema enclosure. They are used with the woofers in a vertical placement. For a horizontal array just use the vertical polar's. You can clearly see issues but these are typically used with a horn dropped on top. Have to wonder just how audible the notches are in actual use.
I have heard several systems using these boxes and as ugly as it may look they sounded just fine.
Everest is a 2 1/2 way.
Rob
"I could be arguing in my spare time"
Old 25th November 2021, 12:23 PM   #43
Lament is offline Lament  United States
Originally Posted by tmuikku View Post
^ if you checkout post #37 attachment the toe out setup seem to combine into nice wave front at least up to the ~700Hz test. The intensity seems to be quite uniform with wide dispersion. The toe in setup makes more distinct main lobe so narrower pattern overal. But jeah even the sims have lots of simplification baked in so I think I've seen examples done both ways, from memory the toe in situation is quite rare though. Some high end products seem to have it (on the vertical axis). Most if not all big monitors using 15" side by side have them flat or toed out? In fact it is quite hard to google up images of these dual woofer systems, there is much more stacked vertically than in the horizontal configuration.
Here is someone building augsburger type thing, with toed in woofers. Some measurements of dual woofer setup in post #49, images and what not later in the thread.
Old School Studio Monitor Build | Page 3 | AVS Forum
Surely a system like this is cool looking but not sure if it is something one would want or need for sound quality. If they were good, they'd be everywhere instead of stacked drivers?
I think both inward and outward angling has merit since they have both been used in studio monitors. It probably works well if the crossover frequency and angle are in 'sync'.
Your simulations make it alot easier to understand how this works, impressive stuff
Old 25th November 2021, 05:32 PM   #44
puppet is offline puppet  United States
Rob
Something that I think has been passed over. Might help if the link I posted was actually read through
  Reply to this post
Directivity of side by side woofersHide this!Advertise here!
Thread Tools
(2) ScanSpeak 25W/8565 woofers, (4) HiVi D6.8 woofers, (2) Eton 7-373 Hex B woofers Jimmy154 Swap Meet 14 11th July 2015 10:11 PM
soft vs hard mid-woofers cones: audible directivity characteristics? crazyhub Multi-Way 43 13th January 2012 10:30 AM
push-push or side by side? Matttcattt Multi-Way 40 7th July 2003 10:48 PM
Side fire sub, how close can magnet be to side? tim_rule Multi-Way 2 2nd February 2003 09:22 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
