Stacking crossover components?
Thread Tools
Old 14th October 2021, 09:04 AM   #11
markbakk is offline markbakk  Netherlands
Wirewound resistors can have serious inductive values, but the low-selfinductance types are so common, that hardly can be an issue. It even is quite good practice in amplifier output stages to wrap some wire for coil around a resistor to create a LP filter.
Mark Bakker
Old 14th October 2021, 06:23 PM   #12
profiguy is offline profiguy  United States
Originally Posted by AllenB View Post
Do you think there might have been some mutual inductance happening there?
LP coil was 4-5 inches away from the tweeter HP coil and at a 90 degree angle. It was also set up for bi-wiring so the LP wasn't even used for testing.
less is more
Old 14th October 2021, 06:37 PM   #13
The end caps on WW resistors are usually steel along with the leads, which do have some mass to them and can act as an inductor core.
Amp output LR series circuits typically are packaged together for convenience purposes to be compact and close to the speaker terminals. They don't need to be that big mainly because the resistor doesn't really see any voltage drop when the amp is reproducing the typical music spectrum as the coil is so small in value. I learned that the hard way as a teenager when I first started working on audio equipment, trying to see how much power bandwidth the amp had at higher frequencies with a sine wave generator and load resistor - the resistor inside the coil started to smoke as I went past 25k or so.... oops!
less is more
Old 14th October 2021, 08:19 PM   #14
AllenB is offline AllenB  Australia
AllenB's Avatar
No, I meant the wirewound resistor with its turns could be linking into the flux created by the inductor etc..
Sink or swim, either way you're going to get wet.
Old 14th October 2021, 10:29 PM   #15
Hmm... never thought of that. The resistor was only around 1 to 2 ohms, so I doubt it could have generated that strong of a field or vice versa pick up anything significant from the inductor.
less is more
Old 14th October 2021, 11:08 PM   #16
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I put resistors on top of an air coil like that all the time (for a BSC shelf filter). No problems. Just make sure it doesn’t rattle.
XRKaudio Store // Manufacturer’s Forum
Old 14th October 2021, 11:08 PM   #17
AllenB's Avatar
@ profiguy,
The resistance is irrelevant, the number of turns isn't.
  Reply to this post
Stacking crossover components?Hide this!Advertise here!
Thread Tools
Stacking Toroidal Transformers.?? PeteM Solid State 1 14th May 2004 09:18 PM
Stacking SAA 7220 chips Bernhard Digital Source 1 2nd April 2004 10:58 PM
“Stacking” Toroids??? Jan Dupont Parts 2 10th June 2003 09:47 AM
Core Stacking fr0st Parts 1 20th March 2003 09:07 AM
Stacking toroids - Ok? harvardian Solid State 23 11th September 2002 05:40 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
