want to do an OB design, first one.
Thread Tools
Old 5th August 2021, 02:05 PM   #21
von Ah is offline von Ah  United States
von Ah's Avatar
Here’s a crazy idea: Dual 10 H baffle above and below the planar suspended between. It would be huge and hideous. A giant grille fabric sock could give it an hourglass shape to make it more svelte.
You’re much better off listening to Charlie, however.
Old 9th August 2021, 06:42 PM   #22
Jbburkett is offline Jbburkett  United States
Just reading this thread with interest i have a couple questions.... First i like the looks of the drivers sv572 has chosen or is looking at. Second i would love to know a few other specs we are looking for.(hopeful freq. i.e 100hz to 18k. also sensitivity of total system.) I also am thinking of a 6db crossover set up to start. Is this correct?
watching
Old 9th August 2021, 06:42 PM   #23
sv572 is offline sv572  United States
I have a kind of Thomas Crown personality. I like the thrill of the chase, or hunt so to speak.
What kind of problems do you think the woofer above the tweeter would create? As far as the baffle complexity is concerned, I work at lowes and live above a complete wood working shop. I've intended all along to use a powered sub. I guess I left that out now that I think about it. My bad. Staying with an MTM design, what type of baffle measurements would be good the start the project with? Roughly i.e. height, width, etc. From what I've researched it seems that some leaves or wings are needed behind and to the sides of the woofers to help tune the response. It seems to me that this would also inherently improve stability of the baffle and its rigidity.
sv572
Old 10th August 2021, 07:12 AM   #24
Pano is offline Pano  United States
Pano's Avatar
Rear wings are not to tune a resonance - at least I hope not! Rear wings are just a way to get a longer path between the front and back of the baffle. Wings are almost like getting a wider baffle, without having a wider baffle. Wings that are deep and/or symmetrical can lead to unwanted resonance.
Take the Speaker Voltage Test!
Old 10th August 2021, 06:19 PM   #25
classicalfan is offline classicalfan  United States
sv572
I suggested back in Post #4 that you build Paul Carmody's Sunflower, which is a well proven MTM design by a person with considerable knowledge and experience in speaker design.
Another excellent option was suggested by Pano in Post #2 to build the well proven Manzanita.
If you think that you can build an MTM OB that sounds as good as the Sunflower then by all means go for it. But you will have to figure out a great deal of the answer on your own.
Don't expect to find simple answers here to complex problems. Asking things like high and wide the baffle should be is a gross oversimplification of the problem.
  Reply to this post
want to do an OB design, first one.Hide this!Advertise here!
Thread Tools
I want to build my first speakers. What design would suit my very weird living room? Henning86 Multi-Way 20 23rd August 2020 10:47 PM
Backloaded horns, do we want delayed bass, and how do we want it? Phenoholic Anonymus Multi-Way 50 20th December 2015 01:46 PM
I don't want one more classic design with Peerless XLS 12" ? Mestinon Subwoofers 3 20th November 2005 09:16 AM
Want to re-box several si t amps in one box. How do I hook up to one power supply? ExJxC Class D 7 22nd September 2005 09:27 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
