That’s why you should not use a ready made crossover. Make it yourself and make it lower than 700 (you can use passive components or a DSP but using a DSP makes it an active crossover and you then need at least two separate 2-channel power amps or a 4-channel).One of my concerns I didn't consider before purchasing the Dayton 10" woofer was that almost all my vocals will be coming from it. I'll have to crossover higher than 400 Hz with a ready made crossover probably 700hz.
You are absolutely right and that is why you carefully have to pick your drivers, especially for a 3-way…I'm not sure but it seems to me a 6.5" or 5" mid woofer would be a better instrument for doing this.
What sounds good is a very subjective thing. I prefer the bass quality from a sealed enclosure. A sealed design is also more forgiving than a vented and therefor easier to get right. The bad part is loss of efficiency but it can be compensated with EQ. Note that I only talk about bass quality and extension. This has nothing todo with the sound quality of the majority of vocals.Would the vocals sound better in a sealed enclosure using my 10" woofers than in the ported enclosure I was planning?
You already got a sealed mid and it’s the one who should handle the majority of vocals. The bass is vented and might get harder to get right than a sealed. But you will loose efficiency with a sealed design and you might perceive it as less “bassy”, but the bass might be of better quality, but it is a personal thing. OMG, I feel like a broken record…If so I would prefer to use a sealed enclosure instead with it.
Too much volume can always be made smaller (e.g. stuff it with a bag of sand until you get the right volume. Too small is tougher even if stuffing can make up for some of it.My only other question would be I'd have way more volume for my sealed 10" woofer than I need, is there a way the I could use the space I have for a better result with sealed enclosure?
Please read the post in this thread and see what happens to textbook crossovers which no doubt these off the shelf units assume:
So you want to design your own speaker from scratch!
even if you don't measure and use manufacturer data (with some applied baffle diffraction and step response - tools exist to do this) - you'll end up with a better crossover design.
The right crossover for you won't be cheap - esp. in Aus sourcing inductors and capacitors. A 3 way design can go from as little as 9 parts to as many as 30 depending on driver behaviour.
I'm inexperienced yes, I'm considering using both of the 10" woofers in a separate subwoofer although I can't find a decent sub amp at reasonable cost and then purchase some more woofers more suitable for vocals.
If I were to make the crossover I'd have to ask forum members for info on every single part in the crossover to make sure it was correct and its relative position and how to link all the parts and how to pinpoint if one part is faulty
In addition if I did anything incorrectly it would likely still not be a good result and at more than twice the cost around $500 for the pair.
I know I have much if not all of the info in the schematic that's been given but I'd still not be confident unless I posted photos of every part in the proposed crossover on the forum for a yes or no approval before purchasing. Seems a lot to expect of any forum member.
I realise this is not the same thing but in this video this $4000 dollar for the pair only has a $20 to $30 crossover. I'll probably end up taking my speakers to a professional to iron out any bugs.
$4000 Revel VS $350 Wharfedale | The Results Might Surprise You! - YouTube
I purchased a Crown Xli 800 pa amp to power the Dayton rs270 8a 10" (100 RMS at 6.8 ohms each) for the lower frequencies hopefully it won't hurt them. The amp is (200 RMS x 2 at 8 ohms)
This way I can use some Dayton RS52AN-8 2" mid domes I have for the frequencies between the SB 6.5" and the tweeter. It has a couple of really good reviews. Here
David Ralph's Speaker Pages - Projects
Dayton RS52AN-8 Aluminum Dome 2″ Midrange – AmpsLab
Hi
I partitioned the speaker box with both sections ported now that I'm using a separate amp to power the woofers.
Interesting the bcae1 calculator recommend half the length port compaired to all the other online calculators I used at 3.2 inches long for 43 mm wide port compaired to 19.5 cm plus everywhere else. I'm not using bcae1 recommendations.
Speaker Box Calculations
- New Crossovers with Hz/db switches & DIY speakers
