Super tweeters
Super tweeters
Thread Tools
Old 27th July 2021, 12:23 PM   #121
mountainman bob is offline mountainman bob  United States
mountainman bob's Avatar
Hey Ronald, thanks for the link.
Yes 5ms seemed a bit on the extreme side when you think about the the difference between the right signal reaching your left ear and vice versa.
The cheapest (decent quality) way for delay is to daisy chain a minidsp 2x4hd right before the super tweeter ($225) it has a inherent delay of 1ms and then more can be added in 0.5 increments. Would give the ability to eq it separately from the main tweeters also which will be under control of the minidsp shd I already have.
Old 29th July 2021, 04:21 PM   #122
The new phone book is here! the new phone book is here!……
I was going through that linked thread and is this the same thing I’m thinking of doing but the ‘echo’ would be delay in my case?
Fixing the Stereo Phantom Center
Originally Posted by Kindhornman View Post
I keep wondering how you can change the center phantom image without changing the R&L channels themselves?
“It's in the paper I linked. You can also look at the impulse file.
Briefly, it's a very short echo applied to left and right. The left echo is in phase, the right echo alternates phase.
This makes no change in frequency response, it sums to zero. But for 2 ears separated by a head, it does make an audible difference because it eliminates some comb filtering in the midrange.
There is a change to left and right (short echo) but it should be inaudible in either of those two channels. It's when they acoustically combine into the center that there is a difference.”
File Type: jpg 852B8AB1-BA80-4163-B914-8D5E6240FFC9.jpg (515.9 KB, 49 views)
Old 29th July 2021, 04:58 PM   #123
Pano is offline Pano  United States
Pano's Avatar
Super tweeters
Ooooooooo, look at that! It's going to be a fun day in the Florida Panhandle.
Old 29th July 2021, 05:03 PM   #124
Not sure if I’ll get to do much with it today but maybe set em up on top of my ns670 and try with a 1uf series cap just to hear them.
The ns 670 would probably benefit the least but it’s all that I have set up at the moment.
So Pano that quote from above (in #122) is yours……is that anywhere near to what I was discussing here earlier?
Old 29th July 2021, 08:08 PM   #125
Pano's Avatar
Super tweeters
As to the quote - yes maybe similar. Good phase control and a well treated room can cause a tonal hole in the phantom center image. There are many tricks to eliminate that hole that is caused by comb filtering around the head.
Hope you get a listen to the tweeters tonight. I've heard Heil or ESS at a couple of audio shows, I was impressed. Tweeters usually found fake to me, those didn't. Don't remember what model I heard.
Take the Speaker Voltage Test!
  Reply to this post
Super tweetersHide this!Advertise here!
Thread Tools
Nirvana super 8 and cast super 8 how do they compare to 206E? freddi Full Range 12 26th March 2017 09:32 PM
Easy Tweeters / Super-Tweeters nonsuchpro Multi-Way 3 2nd March 2016 10:05 AM
Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) hollowman Power Supplies 45 5th July 2013 10:50 PM
audio nirvana super 10 or super 12 tonytex Full Range 11 4th September 2011 10:55 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
